Page 5 of 23 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #41
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by Jarrod View Post
    Sorry for being such an electronics n00b, but can you please help me figure out what voltage I can use for the analog input going by the attached schematic for my steering wheel controls?
    Thanks,
    For the ones going to use the analogin for steering wheel controls or are creating your own keypad, here is a sample schematic that can be used to connect the steering wheel controls to the analog in.
    Is also created an excelnsheet that can be used to calculate the different resistor values and output values. You can use the outputvalues in the RRK8055.ini to configure the analog menu.
    Attached Files Attached Files
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #42
    Oct 2004
    NY
    wow, this is really cool... great work with this, I gotta get me one of those boards
  3. #43
    Mar 2005
    Switzerland (Luzern)
    hi is it possivel to control my cpu cooler ?
    I mean read temperatur and if temperature is higher than 40°c then turn cpu cooler one and then when temperatur goes under 40°c wait some time and then turn cpu cooler off
    on europe this board is avaiable on
    www.conrad.de
    www.conrad.ch
  4. #44
    Apr 2005
    The Netherlands
    Quote Originally Posted by nugomes View Post
    www.conrad.de
    www.conrad.ch
    You can use the analog input to read the temperature and you can use one of the digital outputs to swtich on/off your CPU cooler. You can also use the analog out/PWM pulses to control the speed of your CPU cooler. Maybe with some smart skinning you can automate this. But in my opinion it would be cheaper to get yourself a temp. controlled CPU cooler which will run independantly from RR. On the other hand, paid just 45 euro for the board in the Netherlands (www.conrad.nl) and opens a world of possibilities.
  5. #45
    Mar 2005
    Quote Originally Posted by 307SW_NLD View Post
    hy tanks for the answer
    well I tink my problem will be the "smart skinning"
    I hope some one kan help I would like to use this boar to detect the rear gear and then turn on my rear camera.
    I thik I m going to by the board and see what I can do.
    thanks
  6. #46
    Apr 2005
    The Netherlands
    New version 2.0.0 released
    A new version is released. See first post. Major changes on the menu functionality. Added some features requested by users.
    I'm open for any suggestion/comments.
  7. #47
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    Have to ask a couple questions about this board before I order.... Finally found a place that has them in stock.
    I have ordered some momentary push button switches that I would like to use in my car.
    What I would like to do is press once, and relay/board closes circuit and holds until press again and relay/board opens circuit.
    Also, I would like to be able to do the above, but create a delay for controlling several servo's. I am making my rear monitors flip down from the headliner but don't want to use micro or limit switches.
    And one last question, the link here> http://www.simmetry.com/image.asp?sr...board,+display
    is a touch screen that I want to install in the rear of my SUV to control the board too. Can anyone tell me it these two are compatable?
    Tennessee Vols Fan
  8. #48
    Apr 2005
    The Netherlands
    Quote Originally Posted by Volsfan View Post
    1. You can use the command k8055_do_switch_bit_x to switch the state of bit x of the digital output. You can use the menu functionality of the digital inputs to execute this command. So a button press will execute the k8055_do_switch_bit_x command which will change the state of bit x (which is driving your relay). The state of the output bit can be shown on your monitor by using the k8055_do_bit_x indicator. This indicator is also clickable to change the state of the output.
    2. Nice looking LCD. From what I can read from the documentation, this device is controlled by a serial RS232 port. You will probably need to write your own RR plugin to make the touchscreen execute Road Runner commands. What does the device cost. If I had one I would write a plugin for it.
  9. #49
    Jan 2006
    Kingsport, TN
    It's $89.00 US and 69.4040 EUR
    Here is their main page: http://www.simmetry.com/default.htm
    I really want the touch screen to run several Linear Actuator so it would not necessarily need to be in RR. That screen is for my amp rack and motherboard rack to slide out of the sub encloser in the back of my car
    Thank you for the relpy. I have gone ahead and orderd the board and as soon as it arrives, I'm sure that I will be asking many more questions
    Tennessee Vols Fan
  10. #50
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    so question.... what is everyone using this unit for?
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
