Page 6 of 23 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #51
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    gathering dust on my shelf at the moment.
    Will probably use to control lights or something and pssibly read temperatures.
  2. #52
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    Mine is installed in my car not connected to anything, not even USB. I've got to get myself a USB repeater cable to connect my USB hub too. For some reason my cheapo powered USB hub doesnt work on a standard 5m USB extension cable.
    Jarrod - Holden VX S!
  3. #53
    Low Bitrate mscar's Avatar
    Oct 2003
    Portugal
    HI, Is it possivel to use push button (skin command) in the relay skin?
    Ex: On Click -> open relay1 : On Release -> close relay1 (in the same botton)
    I want to use this command to open or close my electric car windows.
    Ex: Push botton -> open window : Release botton -> stop window.
    :: MSCAR ::
    .:: Multimedia System Car ::.
  4. #54
    Oct 2003
    Portugal
    If not possivel: please reconsider to make a new command like:
    "k8055_do_switch_bit_1"
    "k8055_do_set_bit_1"
    "k8055_do_reset_bit_1"
    "k8055_do_push_bit_1" Set on and off relay
    :: MSCAR ::
  5. #55
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Quote Originally Posted by mscar View Post
    Well, it depends if there is a "button up" event in RR that is getting passed to the extension plugin. As far as I know it isn't there. So for now you're stuck with the k8055_do_switch_bitx which means 1 push start window going down, next push stop window going down.
    k8055_do_push_bit_1 is an idea but how long do the bit need to be set?
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  6. #56
    Oct 2003
    Portugal
    It may be less that a second.
    :: MSCAR ::
  7. #57
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Commands are only executed in RR when you let go of the button. This basically simulates the same functionality of any windows button (on purpose): If you click down a button, move the mouse out of it and let go of the mouse, the button will NOT execute giving you a chance to visually inspect if you pressed the right button in first place.
    However, if you make a clickable area or indicator, you should receive the event as soon as you click down on it, then you could easily monitor the mouse button via windows api: (GetAsyncKeyState(vbKeyLButton) and &h8000) which returns true/false if the mouse left button is down/up respectively. You'd probably have to make a timer on a reasonably short interval to control it though.
    Ride Runner RR's Myspace
  8. #58
    Oct 2003
    Portugal
    Thanks Guino, i made a change in RR CODE
    modK8055.bas
    ' changed by mscar
    Public Sub relays(Index As Integer)
    Dim i As Long
    Dim n As Long
    Dim valor As Integer
    n = 0
    If relays_State(Index) = False Then
    relays_State(Index) = True
    Else
    End If
    For i = 0 To 7
    If relays_State(i) = True Then valor = 1 Else valor = 0
    n = n + valor * (2 ^ i)
    Next
    WriteAllDigital n
    End Sub
    ' add by mscar
    Public Sub relaysPush(Index As Integer)
    Dim i As Long
    Dim n As Long
    n = 0
    Else
    End If
    For i = 0 To 7
    Next
    WriteAllDigital n
    Sleep (50)
    n = 0
    Else
    End If
    For i = 0 To 7
    Next
    WriteAllDigital n
    End Sub
    and i add some code in exec
    Case "relaypush1"
    relaysPush 0
    Case "relaypush2"
    relaysPush 1
    Case "relaypush3"
    relaysPush 2
    Case "relaypush4"
    relaysPush 3
    Case "relaypush5"
    relaysPush 4
    Case "relaypush6"
    relaysPush 5
    Case "relaypush7"
    relaysPush 6
    Case "relaypush8"
    relaysPush 7
    Work Fine now
    :: MSCAR ::
  9. #59
    Apr 2005
    The Netherlands
    modK8055.bas
    ' changed by mscar
    Dim i As Long
    Dim n As Long
    n = 0
    Else
    End If
    For i = 0 To 7
    Next
    WriteAllDigital n
    End Sub
    ' add by mscar
    Dim i As Long
    Dim n As Long
    n = 0
    Else
    End If
    For i = 0 To 7
    Next
    WriteAllDigital n
    Sleep (50)
    n = 0
    Else
    End If
    For i = 0 To 7
    Next
    WriteAllDigital n
    End Sub
    Case "relaypush1"
    relaysPush 0
    Case "relaypush2"
    relaysPush 1
    Case "relaypush3"
    relaysPush 2
    Case "relaypush4"
    relaysPush 3
    Case "relaypush5"
    relaysPush 4
    Case "relaypush6"
    relaysPush 5
    Case "relaypush7"
    relaysPush 6
    Case "relaypush8"
    relaysPush 7
    Work Fine now
    That must be an old version of RR. The newest version of RR does not have a modK8055.bas and the K8055 code was removed. This is now replaced by the RRK8055 Extension plugin
  10. #60
    Oct 2003
    Portugal
    I have the new version...It works with RR and your plugin, in the same time.
    Thanks.
    :: MSCAR ::
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
