Page 9 of 23 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 221
Thread: Velleman K8055 USB I/O Board Extension plugin
  1. #81
    Nov 2006
    Romania
    Many thanks. I will try this
    I suppose i dont have to use a Rv anymore, right?
    Just a 10Ko resistor for the R2...
    My second Subaru skin
    Full screenshots second skin
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  2. #82
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Yep, because you are using regulated 5 volt as the input no need for Rv
    My car: 2006 Hyundai Santa Fe 2.2 CRDI AUT
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  3. #83
    Nov 2006
    Romania
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  4. #84
    Aug 2005
    Athens,Greece
    Quote Originally Posted by 307SW_NLD View Post
    Can I ask a noob question? How exactly do you get the 5v from the K8055??
    I have to admit that I have no clue on electronics...
  5. #85
    Nov 2006
    Romania
    Actually i think the 5V it comes out of the usb...
    that is why the current is limited to the usb specs.
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  6. #86
    Aug 2005
    Athens,Greece
    Quote Originally Posted by mugurg View Post
    So 5v from the positive of the usb, to A1 ? Sorry about that, but as I said I haven't got a clue on electronics, only how to solder things :-)
  7. #87
    Nov 2006
    Romania
    you dont need to get the 5V from the usb to A1. it is already done by using "internal voltage" jumpers SK2-SK3
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  8. #88
    Nov 2006
    Romania
    :d
    @307SW_NLD
    Everything works perfect, i have managed to set all the buttons for my Sony RX controller in the RRK8055.INI.
    What i will like to ask you is how i can make that k8055 to be initalized once the RR start (now works only in relays.skin) , and the controlls of the Sony RX to work in main menu, audio player, and video player as well? basicaly, how can i make that this analog menu allways to work , without interfeering of course with the RR buttons and functions. These should allways work by touchscreen.
    many thanks for your help.
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  9. #89
    Apr 2005
    The Netherlands
    Have the X,RRK8055 in your first screen (probably menu.skin). This screen will load and initialize the plugin. Use the k8055_menu indicator in every screen you want to control with your sony controls. This indicator does not have to be on a visible place.
  10. #90
    Nov 2006
    Romania
    Simply perfect!
    You did a great job! All buttons working perfect now.
    My car photos
    CarPC Progress
    ■■■■■■■ - 75%
  1. Replies: 10
    Last Post: 08-22-2008, 06:36 PM
  2. i think i burn my USB controller board
    By susuking in forum LCD/Display
    Last Post: 01-26-2006, 12:55 PM
  3. USB Control Board component burned
    By carfreak01 in forum LCD/Display
    Last Post: 08-24-2005, 03:43 PM
  4. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
