Page 11 of 42 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 413
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #101
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Nooooooooooooooooo
    Don't do anything that silly.
    Opening windows and flashing lights is one thing, but messing with the cruise control is a big no no as far as I am concerned.
  2. #102
    Low Bitrate wishbone's Avatar
    Feb 2006
    Anyone figured out how to just send "on" and "off" light commands? I've seen flashing commands, and even some that will turn a single light on for 10 seconds. But no LCM type control codes?
    Opus ITX Vehicle PC Case, VIA EPIA MII12000 Mini-ITX Mainboard, Xenarc 700TSV touchscreen
  3. #103
    Dec 2006
    how to connect the rolf V5 USB Version to my e46 323 '99
    Hello:
    I would like to know how and where to connect the rolf V5 USB Version to my e46 323 '99.
  4. #104
    Constant Bitrate jeep642's Avatar
    Sep 2006
    Chevy Chase, MD
    Quote Originally Posted by htatton View Post
    Hello:
    Unless I didnīt understand your question Iīll answer this one before you get *****slaped by the usual suspects on this forum...
    At the opposite end of the USB plug on your adapter you have 4 pins:
    GND : connect to ground
    +12V : connect to +12V(switched) (if you connect it to +12V constant your car may start acting up)
    IBUS : connect to IBUS
    NTSC : donīt worry about this one, if you do go here
    you can find this wires on the adapter at the back of your head unit that looks like this: (the female one)
    GND is number 15 (brown)
    +12V(switched) is number 5 (violet/white)
    IBUS is number 7 (yellow)
    go here and to E46fanatics for more
    I would recommend getting a BMW adapter to avoid messing up the wires in your bimmer adapter.
    Make sure you REALLY canīt find the answer before you ask.
    Iīve been exactly where you are and I found it!
    This is information that I found on the web and worked for me. You should always double check before messing with your car wiring. I donīt want to be responsible if you lit your bimmer on fire!!!
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
  5. #105
  6. #106
    Dec 2006
    Thanks for your help!!!!
  7. #107
    Newbie maddop's Avatar
    Oct 2005
    Liverpool
    There is a website with the information on it for the IBUS lights. I have used them by customising the IbusRR skin. www.hacktheibus.com
    Very good list of codes there. All tested on E46 and work.
    Thanks,
    Paul.
    BMW E46 (year 2000)
    CARPC installed and working!!
  8. #108
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Hi Guys,
    Hopefully your all still subscribed to this thread
    Did anyone else have strange beaviours from the e46's when the car pcs were off?
    for example i left mine unplugged from the computer, but left in the ibus connector
    My indicators didnt work, or make any noise at all, interiours lights didnt work including the ones in the speedo panel, so in the dark you cant see anything, as soon as a unplug the interface everythings normal again, very dangerours!
    Also you may wanna read this to prevent urselfs doing what i done today ibus frys my laptop?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  9. #109
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    HacktheIbus is gone.
    I'm trying to collate as much info as I can about the IBUS on the new BMW-carputers.co.uk site.
  10. #110
    Sep 2006
    Chevy Chase, MD
    Quote Originally Posted by jonessc View Post
    Hi Guys,
    I had the same problem and I fixed it by switching 12v constant to 12v ignition or vice versa to the ibus controller and all went back to normal.
    at the
    CAR PC NETWORK
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
