Page 12 of 44 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 438
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #111
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    HacktheIbus is gone.
    I'm trying to collate as much info as I can about the IBUS on the new BMW-carputers.co.uk site.
    Do you still have all the ibus codes?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #112
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Radiotrib has been in email contact with the owner of hacktheibus and he is willing to pass on the data, if he still has it, and when he has time. So maybe.
    However I want to try and collate as much as possible from all possible sources including here.
  3. #113
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    Is anyone using this with StreetDeck?
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
  4. #114
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Seing as it's an RRplugin I doubt it.
    However it depends on whether SD can send user specified commnads to an external app. If so, then it might work.
  5. #115
    Nov 2006
    Wales, UK
    E (aka marathon runner),
    How did you get on with this?
    I managed to find a copy of an old ibuscomm before it was modified, the help txt file, seems to have all of the codes commented out including navigation/idrive codes
    Let me know if u want it.
    Gettin harder to find the info esp on yahoo forums it seems to be dieing off
    CarPuter Progress:
  6. #116
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well it's a bit quiet over there, getiing quite a few [people joining but no one posting.
    If you have any Ibus Info the by all means pop over there and post it in the iBus section.
  7. #117
    Feb 2008
    Any chance it can be posted here? Trying to figure out Resler's iBus and how to mount it to my car and get everything working, but I have no idea where to start. Still searching 'ibus' on the site, but really not getting anywhere. Any chance someone can post a picture of how the interface works between the car and the computer also?
  8. #118
    Feb 2008
    Ireland
    Thanks a lot for iBusRR!
    Is it possible to get the source code for this?
  9. #119
    Dec 2004
    Mi car is a E46 Compact 03 I`m working on IBUS with analyser and this is what I get:
    Ibus Codes:
    CODES WORKING
    D0 07 BF 5C FE 3F FF 00 0A WHEEL LIGHTS ON
    D0 07 BF 5C FF 3F FF 00 0B WHEEL LIGHTS OFF
    D0 08 BF 5B 05 00 00 00 00 39 LED LIGHTS ON
    D0 08 BF 5B 04 00 00 00 00 38 LED LIGHTS ON TOO
    D0 08 BF 5B 01 00 00 00 00 3D LED LIGHTS OFF
    D0 08 BF 5B 00 00 00 00 00 3C ALL LEDS OFF
    80 0A BF 13 00 01 00 00 00 00 30 MOVE LIGHTS
    80 0A BF 13 01 00 00 00 00 00 31 MOVE LIGHTS TO DIFERENT POSITION
    80 0A BF 13 01 00 00 04 00 00 31 ????
    80 0A BF 13 01 01 00 00 00 00 31 ????
    D0 08 BF 5B 60 00 04 00 00 58 DIRECTION LIGHTS(ON DASHBOARD ONLY)
    3F 05 00 0C 02 01 OPNE TRUNK
    CODES NOT WORKINF
    D0 08 BF 5B 00 00 00 00 00 3C TURN OFF LONG LIGHTS
    00 05 BF 7A 51 21 B0 LIGHT INSIDE ON
    00 05 BF 7A 11 21 B0 LIGHT INSIDE OFF
    I need to turn on and off lights and direction lights. Can anyone help me? Thanks
    Good night!
  10. #120
    May 2005
    Stockholm
    Quote Originally Posted by trr330xi View Post
    If you have the 232 version just plug it into the serieport on your carpc. Then connect the ibus connection with a wire to the IBUS cable in your car. I think it's white/yellow in all BMW. At least it's white/yellow in E39.
    Connect the GND and +12V to your CarPC. Yellow and black cable. Then just download IbusRR and put it into startup menu.
    In my E39 touring I have connect the IBUS cable in the left back side in the trunk. There is a plug with three cables. One of them is yellow/white.
    GND is number 15 (brown)
    +12V(switched) is number 5 (violet/white)
    IBUS is number 7 (yellow)
    Now you are done and you can test and adjust the volume from your steering wheel.
    Good luck
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 02:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 12:47 PM
