Page 15 of 45 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 445
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #141
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by radiotrib View Post
    Hi Warfield .. I've made a couple of hacks to enable ffwd/frwd functionality on the steering wheel hold, repaired the e39 scrolling, and altered the phone and R/T buttons so the phone does play/pause (as the old R/T did) and T/R toggles between audio and gps.
    If you want the modified source to put right and continue from there, its at
    http://www.trib-design.com/images/in...usComm_RT2.zip
    Enjoy
    Very nice, ive made a few mods to the 1.89 ibuscomm, glad you kept the keyboard settings in the ini (i use the voice button, to send F2). This is a good base to work with we just need to conquer the hibernation/reload issues. Its intermittent for me, most of the time I have to close and re-load to work properly
    Anyone got the cluster display to display text as well. I believe from yuor posts Warfield you developed this with Sama/Darth many moons ago
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #142
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Quote Originally Posted by WaRFiElD View Post
    Just to let everyone know I'm back in the CarPC world
    I'm highly opened to new suggestions so don't hesitate to send them via PM.
    New features for now will include steering wheel scrolling support in the audio player/browser pages (to keep hands free) and better hibernation support for those having to restart iBusRR after resume.
    Keep in mind that I'm focusing on RR as it's currently my only installed frontend in the PC and I'm using the COMSend method to send and receive data from RR which limit my support on other FEs. I'll be releasing the source code along with my next release for those interested in other FEs.
    Cool. Can you put the name of the window you are sending messages to in the ini so we can control other front ends?
  3. #143
    Jun 2007
    Den Haag
    Quote Originally Posted by kelmk View Post
    That's already there. You'll find an entry
    ; Application to send event to (Windows Title)
    ; Note that application must be started before IBusComm in that case.
    ;AppCaptionSendEventTo="<* BeBoX Multimedia Player *>"
    ;AppCaptionSendEventTo="Sans titre - Bloc-notes"
    AppCaptionSendEventTo=""
    ;AppClassSendEventTo=""
    Pretty self-explanatory. Open the app. Look at the title bar and take down the window title exactly. If you can't see a title bar, look at your task bar and use the title shown there for thhe open app.
  4. #144
    Aug 2005
    Canada
    This entry has been ripped out from the current iBusRR but will be re-added in the next release. I'm currently working on re-writing the entire function that parses I-BUS messages to be able to efficiently extract useful data from the I-BUS like outside temp, current Speed/RPM, etc. The ini file might change as well because everything is going to be pretty different from IbusComm.
  5. #145
    Feb 2008
    Ireland
    Good stuff WaRFiElD!
    Here's some data IBUS shows about the car (from NavCoder log):
    - Engine RPM
    - Speed
    - Total Km
    - Outside Temp
    - Coolant Temp
    - Handbrake status: on/off
    - Gear status: P/R/N/D
    - Engine Status: on/off
    - Lights (Indicator/Fog/Low/Hi) status: on/off and ok/error
  6. #146
    Aug 2005
    Canada
    Here's an update on the current progress:
    Working sensors: Engine RPM, Speed, outside temperature, current fuel consumption, range left in fuel tank
    The FFWD/FRWD is working with the steering wheel (can scroll in audio player and do ffwd in the menu). I'm currently searching for a way to make it more customizable in the ini file. I'd also like coolant temp but I haven't find the exact message yet. Anybody has a clue??
  7. #147
    Feb 2008
    Ireland
    Nice!
    Im not sure on the code but here is a NavCode log that looks like the coolant temp comes from the same data as the outside temp:
    IKE --> GLO : Temperature: Outside 15C, Coolant 90C
    IHK --> IKE : Cmd_0x83, Data="00 08"
    IKE --> GLO : IKE sensor status: Handbrake_On Motor_Running
    IKE --> GLO : Speed/RPM: Speed 0 km/h, 600 RPM
    EWS --> IKE : Odometer request
    IKE --> GLO : Odometer: 149,644 kms
  8. #148
    Aug 2007
    SF
    Can't wait!
  9. #149
    Aug 2005
    Canada
    I'm waiting for your comments on the new v2.0.0 release!
    please don't forget to delete your old .ini file first
  10. #150
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 02:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 12:47 PM
