Page 17 of 45 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 445
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #161
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Resuming from standby works fine.
  2. #162
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by WaRFiElD View Post
    is hibernation working for everyone?
    Will let you know after a few days. My old ibuscomm would give up after 2-3 resumes then id have to close and re-open. Looking good so far tho
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  3. #163
    Feb 2008
    Ireland
    Will test this more after I get my PC back in the car in a few days...HDD messed up.
  4. #164
    Aug 2005
    Canada
    good news, coolant temp is coming on the next release.
    I'm thinking of using the light intensity messages to control the gamma values of RR but is there a command to set a numerical gamma value? like 0-100%? I only found DAYGAMMA/NIGHTGAMMA in skin commands.txt
  5. #165
    Aug 2007
    SF
    I would like to modify the LSXVoid main screen to display some of the info coming from this like RPM and temp. Can you give me a quick how to? I'm new to RR.
    Nov 2006
    Wales, UK
    Its survived every hibernation so far!
    CarPuter Progress:
  7. #167
    Nov 2006
    Wales, UK
    Prob have to use an alternative gamma program, RRconfig only allows a day/night gamma settting.
    CarPuter Progress:
  8. #168
  9. #169
    Nov 2006
    Wales, UK
    Does this version change the time on the OBC?
    I aint changed my clock since the clocks changed, the time is now spot on to my pc clock since i switched to this 2.0 release? :weird:
    either that or ive got a ghost / the OBC has some weird DST settings
    CarPuter Progress:
  10. #170
    Aug 2005
    Canada
    Yes it does sync the OBC clock with the PC
    it has an option in the ini file if you wish to disable it but it's enabled by default(SyncTime=1)
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
