Page 20 of 45 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 445
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #191
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    If helps the debug im still using 2.0 and got the com port open issue after hibernation, first time in 14 resumes
    Il put the new version in Tuesday
    Working awesome other than that...
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #192
    Aug 2005
    Canada
    Should the log file be from just before I turn on ignition or the engine? I guess I can create a log file with iBusanalyzer? Or should it be done in another way?
    before you turn ignition on and yes a plain ibusanalyzer log would be perfect!
  3. #193
    Feb 2008
    Is it possible to get iBusRR to respond to the radio polling for the CD Changer?
    I'm not having any luck getting ibuscomm to respond to it on an E46 and thus cannot remove my CD changer to plug the PC audio and iBus connections into.
    Is this possible? has anyone managed to emulate the CD Changer on an E46?
  4. #194
    Nov 2006
    Wales, UK
    Quote Originally Posted by Assault View Post
    I use a car 2 pc adaptor that connects to the head unit and emulates the cd changer, but i believe the base version of ibuscomm did have an option in the ini file to support it, not sure if warfields version has it.
    CarPuter Progress:
  5. #195
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Ok, I went in the car and tested Coolanttemp. It works!
    So I made a logfile as you asked. This is it:
    Code:
    -- Start Scan
    Source Device      : Nav Locat.
    Destination Device : Light Ctrl
    Data  - - - - - - - - - - - -
    02 00
    Full Packet - - - - - - - - -
    D0 04 BF 02 00 69
    Source Device      : IKE
    11 03
    80 04 BF 11 03 29
    5B 00 00 00 00
    D0 07 BF 5B 00 00 00 00 33
    Source Device      : UNKNOW 1
    51 10
     Q  .
    30 04 BF 51 10 CA
    5B 00 00 00 00
    5B 00 80 00 00
    D0 07 BF 5B 00 80 00 00 B3
    5B 00 80 00 00
    Source Device      : IKE
    Destination Device : Nav Locat.
    53
     S
    80 03 D0 53 00
    Destination Device : IKE
    54 42 53 06 18 80 0B 0C 00 81 00 00 00 05
     T  B  S  .  .  .  .  .  .  .  .  .  .  .
    D0 10 80 54 42 53 06 18 80 0B 0C 00 81 00 00 00 05 18
    Source Device      : IKE
    18 00 00
    80 05 BF 18 00 00 22
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    19 0F 18 00
    80 06 BF 19 0F 18 00 37
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    19 0F 18 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    Source Device      : IKE
    19 0F 18 00
    Source Device      : IKE
    18 00 00
    5B 00 80 00 00
    Source Device      : IKE
    18 00 00
    -- 36 valid packet(s)
    -- 0 unknow packet(s)
    -- 36 filtered packet(s)
    -- 0 error(s)
    -- End Of analysis
    -- Stop Scan
    This one is just with the ignition turned on. I also have one with ignition on, glowing the engine (it's a diesel) and starting the engine. I didn't put it here because of the size but just ask for it if you need it.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  6. #196
    Aug 2005
    Canada
    Thanks Bimmerstyle, I'll have outsidetemp working for you on the next release. However it won't be until the end of the month because I'm going on vacation and I'll be back on may 31.
    @Assault: I'll also take a look to add an option for cd polling response. I just need to read some old posts to find what were the ibus messages (polling + answer)
  7. #197
    Feb 2008
    WaRFiElD, thats easy
    The Radio polls the CD Changer with: 6803180172
    The CD Changer (or iBusRR) is supposed to respond with: 1804FF0200E1
  8. #198
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Quote Originally Posted by WaRFiElD View Post
    I'll wait for other inputs but unfortunately I can't reproduce the hibernation/resume problems on my CarPC or my 2 homePCs so I'm doing guesswork! What is your mainboard and windows version?
    It may be a hardware problem on my end. I'll sort that out first. IbusRR is either crashing on loosing the com port every resume now.
  9. #199
    Sep 2006
    Belgium
    No problem. The car is in the garage since yesterday anyway. My dad is gonna pull out the engine block and do a small overhaul on it. It will be at least a week until it's ready, probably even a little longer. So there's no rush.
  10. #200
    Jun 2007
    Den Haag
    Heya Warfield .. I'm back after a couple of business trips - looks like you've been busy. Is there any chance of getting hold of the source so that I can update my previously modified version with your new changes to improve my understanding of the process ... I'd be grateful.
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 02:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 12:47 PM
