OK, found out some info today. Try this for starters, and add your own findings to it:
Bit mappedCode:3F 0C D0 0C 00 00 00 00 21 20 00 00 00 EE TX LL RX MM DB1....................DB9 CS
7... ...0 Bits
DB4
x1xx xxxx = side market left
1xxx xxxx = side market right
DB5
xxxx xxx1 = centre stop light
xxxx 1xxx = stop light left
xxx1 xxxx = stop light right
xx1x xxxx = indicator front left
x1xx xxxx = indicator front right
DB6
xxxx xx1x = low beam right
xxxx x1xx = low beam left
xxxx 1xxx = taillight left
xxx1 xxxx = high & low beam left, alternating
xx1x xxxx = high & low beam right, alternating
If only I had an E46 I could test these further. In an hours work, you'd have all lights documented.
LinkBack URL
About LinkBacks
