Page 42 of 45 FirstFirst ... 3233343536373839404142434445 LastLast
Results 411 to 420 of 445
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #411
    Mar 2011
    Germany Oldenburg
    Is there a possibility to repeat the command?
    for example: that this is sent every 10 seconds so that the light was not going. remains always on?
    And you can also respond to commands ibus?
    for example:
    11/04/2011 21:35:53.625: D0 BF 07 03 5B 80 00 00 B0
    11/04/2011 21:35:53.625: LCM -> GLO: Lamp status: Park Low_Beam Faulty: Number_Plate
    to automatically reply:
    [ID: stand]
    MsgTemplate = "3f0cd00c000000000001200000"
    TTR = 1
    I also often get a runtime error 5
    (Drive an E39)
    Attached Files Attached Files
  2. #412
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Why would need to keep turning on the lights? Surely once they have been turned on they stay on until you turn them off.
    You can add a command to send in iBusRR.ini to any ibus command.
  3. #413
    Mar 2011
    Germany Oldenburg
    IbusComm can for example.
    Since it looks like this:
    [ID: RAD_CDPLAY]
    MsgTemplate = "6805183803004E"
    Label = "asks Radio CD Play"
    Parse = True
    System = True
    ProcessEvents = Enable
    ReplyMsgID = CD_RADSTARTPLAY_100 <----------
    ; KeyBoardMap = "{F9}"
    RRCommand = "RESUME"
    The answer even if your radio to the CD changer that thinks it looks it would be a turn.
    _____
    And in my country it is prescribed to have parking lights on.
    So I was like the light goes on when the PC is on.
    And it is when the PC goes into standby, go back out.
    Or if the boot is on, the indicator will go on.
    Trunk to blinker out
  4. #414
    Feb 2012
    Anyone using this on a e39?
    I did last night and it was a bit messy.
    First none of my windows do move when clicking the icons. I can not lock/unlock the car either.
    The lights buttons barely do anything, or do get other lights going as opposed to the one that was supposed to work.
    My headlight halos do not work at all and foglamps do not work either by clocking them.
    Also this morning when I took the car out, I noticed my indicator light from the cluster does not work anymore. I probably need to give the battery some time off.
    To me it looks like this does not work properly on the e39, I read before some iBus commands are different. I can't see why would they have bothered giving similar functions different codes between the e46 and the e39, but it seems to be the case. Or I missed something.
  5. #415
  6. #416
    Feb 2012
    Quote Originally Posted by Enforcer View Post
    Not all the functions work on all the different models
    Yeah I have learned since that the e39 is not a full iBus build. Thus only a few functions are available.
    Only the e46 is a full iBus build, and probably the e53 is too. But not the e39 and e39 most likely.
  7. #417
    Mar 2011
    Haarlem
    Hi Enforcer,
    It's been a while since I have visit this thread. I have a question about intergrating a code that will allow a automatic switch from menu.skin through to the PDC.skin by using the "0x13 IKE sensor status" code IKE Sensor Status "13 02 10 00 00 00 00 38 // in reverse" and "13 02 00 00 00 00 00 38 //out of reverse". So that Riderunner automatically switches from the MENU.skin through to the PDC.skin and back because of the activation using the code from the IBusRR.exe
    I hope to hear from you.
    Best regards
    Nick
  8. #418
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try
    Add to iBusRR.ini in the [IBusIdsDefine] section
    PHP Code:
    IKE_REVERSE
    =45
    IKE_REVERSE_EXIT
    =46
    and then underneath the steering wheel commands but before codes to send.
    PHP Code:
    ;Reverse Selected
    [ID:IKE_REVERSE]
    MsgTemplate="1302100000000038"
    KeyboardMap="IBUSPDC"
    ;Reverse exit
    MsgTemplate="1302000000000038"
    KeyboardMap="IBUSPDCEXIT"
    Then add to exectbl.ini
    PHP Code:
    "IBUSPDC","",pdc.skin
    "IBUSPDC","load;pdc.skin"
    "IBUSPDCEXIT"
    ,"exit",pdc.skin
    NB this will go to the PDC skin no matter what screen RR is in if reverse is selected. If you want it only if RR is on the menu screen then change the
    to
    "IBUSPDC","load;pdc.skin",menu.skin
    in exectbl.ini
  9. #419
    Mar 2011
    Haarlem
    Hi Enforcer,
    First of all I would like to thank you for the quick reply. I have still a question can you check for me if these are the places where I should put the info?
    These is mine IBusRR.ini
    ; IBUS plugin for Road Runner.
    ; Configuration File.
    ; written by WaRFiElD ([email protected]) May 2008
    ; v1.0.0
    ; Parts of the code taken from the original program IBusCOMM from Franck Touanen ([email protected]) Sept.2003.
    ; General Plugin Setting
    ; ComPort: COM port number. Valid range: 1 to 10 (Required)
    ; FrontEndName: Front End Window name. If none is specified then "RoadRunner" will be used.
    ; InterMsgDelay: Time between 2 IBus messages in miliseconds. Usually set to 10-30 depending on your computer. (Required)
    ; HoldRepeatDelay: Time between 2 RoadRunner Commands when holding next/prev button (if REPEAT_HOLD_CMD=1)
    ; SyncTime: Option to set IKE time with the PC Clock each time iBusRR is started. Default is 0
    ; SetGamma: Option to send NIGHTGAMMA to RR when the lights are turned on and DAYGAMMA when they're turned off
    [Settings]
    ComPort=1
    FrontEndName="RoadRunner"
    InterMsgDelay=31
    HoldRepeatDelay=500
    SyncTime=1
    SetGamma=1
    ; Steering Wheel Definitions
    ; NOTE: Use only data portion of the message
    ; Example: PREV_PRESS: 50 04 68 3B 08 0F
    ; |-----| <--- Data
    [SteeringWheel]
    ;Steering Wheel < Press
    PREV_PRES="3B08"
    PREV_REL="3B28"
    PREV_HOLD="3B18"
    ;Steering Wheel > Press
    NEXT_PRES="3B01"
    NEXT_REL="3B21"
    NEXT_HOLD="3B11"
    ;Steering Wheel + Press
    PLUS_PRES="3211"
    ;Steering Wheel - Press
    MINUS_PRES="3210"
    ;Steering Wheel PHONE Press
    PHONE_PRES="3B80"
    RT_PRES="01"
    ;Reverse Selected
    [ID:IKE_REVERSE]
    ;Reverse exit
    [ID:IKE_REVERSE_EXIT]
    ; RoadRunner skin commands -------------------------------------------------------
    ; [default.commands.skin] Default command to execute when not on a .ini defined RR Screen
    ; [{RRScreen}.skin] Commands to execute on the specified RR Screen
    ; I.E. menu.skin, audioplayer.skin, etc
    ; PREV_PRES: Execute when previous button is pressed
    ; PREV_QUICK_REL: Execute when previous button is released within 1 second
    ; PREV_HOLD_REL: Execute when previous button is released after 1 second
    ; PREV_HOLD: Execute when previous button is held for 1 second
    ; NEXT_PRES .... Same as previous!
    ; REPEAT_HOLD_CMD If true, repeat the HOLD command every HoldDelay until button
    ; is released. Useful for scrolling in audio/browser player
    ; [SwitchScreens] You can replace any command by !SWITCHSCREENS! and define here
    ; which screens you want your button to switch.
    ; NumberOfScreens Number of screens to switch between
    ; 0= ... 1=... RR Command to execute for switching.
    PREV_PRES=""
    PREV_QUICK_REL="PREV"
    PREV_HOLD_REL="STOPFRWD"
    PREV_HOLD="STARTFRWD"
    NEXT_PRES=""
    NEXT_QUICK_REL="NEXT"
    NEXT_HOLD_REL="STOPFFWD"
    NEXT_HOLD="STARTFFWD"
    PLUS_PRES="VOL+"
    MINUS_PRES="VOL-"
    PHONE_PRES="!SWITCHSCREENS!"
    RT_PRES="PLAY"
    REPEAT_HOLD_CMD=0
    [menu.skin]
    PREV_PRES=""
    NEXT_PRES=""
    PLUS_PRES="VOL+"
    MINUS_PRES="VOL-"
    RT_PRES="PLAY"
    REPEAT_HOLD_CMD=0
    [audio_player.skin]
    PREV_PRES="DOWN"
    PREV_QUICK_REL=""
    PREV_HOLD_REL=""
    PREV_HOLD="PGDOWN"
    NEXT_PRES="UP"
    NEXT_QUICK_REL=""
    NEXT_HOLD_REL=""
    NEXT_HOLD="PGUP"
    PLUS_PRES="VOL+"
    MINUS_PRES="VOL-"
    RT_PRES="PLAY"
    REPEAT_HOLD_CMD=1
    [audio_browser.skin]
    PREV_PRES="DOWN"
    PREV_QUICK_REL=""
    PREV_HOLD_REL=""
    PREV_HOLD="PGDOWN"
    NEXT_PRES="UP"
    NEXT_QUICK_REL=""
    NEXT_HOLD_REL=""
    NEXT_HOLD="PGUP"
    PLUS_PRES="VOL+"
    MINUS_PRES="VOL-"
    PHONE_PRES="SELECT"
    RT_PRES="BROWSE"
    REPEAT_HOLD_CMD=1
    [SwitchScreens]
    0="MAIN"
    1="AUDIO"
    2="GPS"
    ; RoadRunner to I-BUS Messages Definitions-----------------------------------------
    ; Note that those codes only work on an E46, see MP3car.com for E39 codes
    ; and modify them for your needs
    ;Open Trunk
    [ID:OPEN_TRUNK]
    MsgTemplate="3F05000C0201"
    TTR=0
    ;Open Sunroof
    [ID:OPEN_SUNROOF]
    MsgTemplate="3F05000C7E01"
    TTR=3
    ;Close Sunroof
    [ID:CLOSE_SUNROOF]
    MsgTemplate="3F05000C7F01"
    TTR=3
    ;Open Driver FRONT Window
    [ID:OPEN_DRIVER_FRONT_WINDOW]
    MsgTemplate="3F05000C5201"
    TTR=2
    ;Open Driver REAR Window
    [ID:OPEN_DRIVER_REAR_WINDOW]
    MsgTemplate="3F05000C4101"
    TTR=2
    ;Open Passenger FRONT Window
    [ID:OPEN_PASSENGER_FRONT_WINDOW]
    MsgTemplate="3F05000C5401"
    TTR=2
    ;Open Passenger REAR Window
    [ID:OPEN_PASSENGER_REAR_WINDOW]
    MsgTemplate="3F05000C4401"
    TTR=2
    ;Close Driver FRONT Window
    [ID:CLOSE_DRIVER_FRONT_WINDOW]
    MsgTemplate="3F05000C5301"
    TTR=2
    ;Close Driver REAR Window
    [ID:CLOSE_DRIVER_REAR_WINDOW]
    MsgTemplate="3F05000C4201"
    TTR=2
    ;Close Passenger FRONT Window
    [ID:CLOSE_PASSENGER_FRONT_WINDOW]
    MsgTemplate="3F05000C5501"
    TTR=2
    ;Close Passenger REAR Window
    [ID:CLOSE_PASSENGER_REAR_WINDOW]
    MsgTemplate="3F05000C4301"
    TTR=2
    ;Open/Close doors
    [ID:LOCK_DOORS]
    MsgTemplate="3F05000C9701"
    TTR=1
    ;Set Speedlimit Off
    [ID:SPEEDLIMIT_SET_OFF]
    MsgTemplate="3b0580410908"
    TTR=1
    ;Set Speedlimit 0Km/h
    [ID:SPEEDLIMIT_SET_0]
    MsgTemplate="3b068040090000"
    TTR=1
    ;Set Speedlimit 50Km/h
    [ID:SPEEDLIMIT_SET_50]
    MsgTemplate="3b068040090032"
    TTR=1
    ;Set Speedlimit to Spedo
    [ID:SPEEDLIMIT_SET_SPEDO]
    MsgTemplate="3b0580410920"
    TTR=1
    IKE_REVERSE=45
    IKE_REVERSE_EXIT=46
    ; lights
    [ID:TURN_LIGHTS_OFF]
    MsgTemplate="0004BF7600"
    TTR=1
    [ID:FLASH_WARN]
    MsgTemplate="0004bf7602"
    TTR=1
    [ID:FLASH_LOW]
    MsgTemplate="0004bf7604"
    TTR=1
    [ID:FLASH_LOW_WARN]
    MsgTemplate="0004bf7606"
    TTR=1
    [ID:FLASH_HI]
    MsgTemplate="0004bf7608"
    TTR=1
    [ID:FLASH_HI_WARN]
    MsgTemplate="0004bf760A"
    TTR=1
    [ID:FLASH_LOW_HI]
    MsgTemplate="0004bf760C"
    TTR=1
    [ID:FLASH_LOW_HI_WARN]
    MsgTemplate="0004bf760E"
    TTR=1
    [ID:FLASH_LOW_SMALL]
    MsgTemplate="8004BF1103"
    TTR=1
    [ID:FLASH_TEST1]
    MsgTemplate="0004bf7611"
    TTR=1
    Thanks so far for the help I really appreciate it.
    Greetz
    Nick
  10. #420
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Wow!
    That's completely different to the ini I have.
    Looks like things have changed since I last used it.
    Sorry no idea with that ini where to stick the bits I have given you.
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
