Page 44 of 45 FirstFirst ... 343536373839404142434445 LastLast
Results 431 to 440 of 445
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #431
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looking at your ini and the first post, it looks like warfield has concentrated more on sending info to the iBus rather than the other way around.
    Whilst he has retained the receiving of info from the iBus he has done in such that only info he has already programmed in it will be sent.
    IE the steering wheel commands plus the sensors that he has created variables for.
    So I would say the only way to get the PDC code in, would be for Warfield to code for them.
  2. #432
    Mar 2011
    Haarlem
    Thanks for your quickreply.
    I have to agree with you.. if I compare your ini with mine. The problem I run into if Warfield has to code them is that I can't get in touch with him... I tried this forum and his email from the ini but no reaction. Do you have maybe an alternative?
    Greetz
    PS I tried today the adds in your ini file but this doesn't do anything? I add the codes also to the exectbl.ini
  3. #433
    Mar 2011
    Haarlem
    Enforcer,
    Sorry to bother you again....I saw that you also know a bit about the plugin in RRPDC... I am also using the plugin...the problem is that he doesn't switch to the PDC.skin because I am using the OEM PDC function on mine E46 convertible. I was wondering if you know a soulution or if it is possible to add the codes to the ini file of the RRPDC plugin.
    Let me know
    best regards
  4. #434
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not sure exactly what you are trying to do withe the RRPDC plugin and the iBus.
    Are you trying the use the RRPDC plugin with the OEM Sensors?
  5. #435
    Mar 2011
    Haarlem
    Well that was the idea but I don't think it is possible.... But I want to know is wat kind controller is use with the RRPDC plugin. Is it a stand alone reverse interface trigger . Or is it built in the pdc device.. Basicly what I want is for roadrunner to switch to the rrpdc.skin when in reverse and change back when out of reverse . Sing the RRPDC.skin.
    Sorry for my ignorence
  6. #436
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The RRPDC plugin in tied to a particular USB box to work with a certain PDC unit.
    It gets the reverse trigger from that, and cannot work on it's own.
    So no, the RRPDC plugin won't work with the OEM PDC.
  7. #437
    Mar 2011
    Haarlem
    Okay, that's to bad. So than I have to tred it again with Ibus.... I will try again with your codes to get the Ibus react on the ibus code and switch to the pc.skinheads there has to be a way to get it to work...
  8. #438
    Nov 2010
    Quote Originally Posted by Nickyboy View Post
    .... Yeah I already though that would be the problem with IbuscommunicatoRR....
    Since my plugin is mention....
    Scrolling problem is most likely related to your interface/drivers.
    If I'm remember right there were you and Matt that had problem with scrolling, both were using Resler old V6 with 5.4 drivers.
    Matt replaced his interface to the new V6 (jan 2011 version) and newest drivers (v6.3) and the problem was gone.
    /Janne
  9. #439
    Jan 2006
    Dublin, Ireland
    The download for this has just three files - iBusRR.exe, iBusRR.ini and LTS.ini
    Sorry but where should I place these files - in Program Files/RideRunner/Plugins or in the User/RideRunner/Plugins ? And is it just a skin which will activate the plugin ?
  10. #440
    Oct 2008
    Wiltshire, UK
    From the best of my recollection it will need to go in the User/RideRunner/Plugins directory.
    (as most installs are now run from the local profile)
    I think that you may also have to embed the app?
    If you run RRCONFIG.exe and select General -> Embedded Apps, you can add iBusRR.exe here. This will make sure the program is run when RR is opened and the skin can talk to iBusRR.
    If any of this is wrong then it's because my brain is hazy as it has been a long while since I have had to do this.
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
