Page 8 of 42 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 413
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #71
    Newbie maddop's Avatar
    Oct 2005
    Liverpool
    ibusrr.ini
    Here it is.
    I think the problem will relate to the message id number... I just picked a random number!
    Attached Files Attached Files
    BMW E46 (year 2000)
    CARPC installed and working!!
  2. #72
    Aug 2005
    Canada
    just remove 'CK' in your message which means checksum, this will be calculated automatically by iBusRR (as stated in the .ini definition syntax)
    the message id does not matter, as long as there is one. In fact this should be removed in the next version
    I also sugest you to put a "TURN_LIGHTS_OFF" message
  3. #73
    Oct 2005
    Liverpool
    Thanks,
    Its working now.
    I'll try to work something out similar to iLights now!
    Cheers,
    maddop
    BMW E46 (year 2000)
  4. #74
    Constant Bitrate jeep642's Avatar
    Sep 2006
    Chevy Chase, MD
    I Bus acting up
    I just installed the Resler adapter in my E46.
    The steering wheel control are working with RR but:
    here are the issues:
    if computer turned off
    Blinkers, high beams, door ajar etc etc lights on the dash don´t work.
    The blinkers don´t make any sound. (tic tac tic tac)
    The wireless entry doesn´t work at all. (as well as the alarm)
    The DSC (traction control) light stays on if turned on.
    Also, just this morning, I turned off the PC, stayed in my car for a bit
    with keys in the ignition, I could ear the annoying ¨beep beep¨ sound but
    when I took the keys out of the ignition the sound kept going on even
    with all door closed. When i turned the car back on it finally stopped !
    if computer on
    Lights and sounds are working.
    The DSC light still gets stuck once on.
    If I lock the car and wait about 30-45 minutes, everything (at least the keyless entry) seems to be working again.
    I´m using the USB Resler adapter
    I powered it with 12V always on (should I switch to on/off 12 V ?)
    It seems that when the computer is off the Resler adapter kinda mess up the whole Ibus communication in the car.
    I have attached the Ibuscomm.ini file. (I added a .zip extension to upload it, it´s not a .zip file)
    There´s a lot of info I´m not using in it.
    I don´t have a head unit (directly hooked up the PC to the car amp), I don´t have GPS, CD changer or anything special.
    Should I clean it up and leave only (for now) the steering wheel control commands. I´d like to add the lights and windows command later on.
    Has anybody ever heard of this, does it make any sense?
    Anybody?
    Cheers
    Thanks in advance.
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
  5. #75
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by jeep642 View Post
    I powered it with 12V always on (should I switch to on/off 12 V ?).
    This I suspect would cause those problems. try switching to powering off the ACCs
  6. #76
    Sep 2006
    Chevy Chase, MD
    I´m gonna go check it out RIGHT NOW !!!
    thanks Enforcer
    at the
    CAR PC NETWORK
  7. #77
    Sep 2006
    Chevy Chase, MD
    @ Enforcer : BINGO that was it! thanks man! it kind of makes sense...
    @WaRFIELD : is there any real difference between iBusRR and iBuscomM ?
    Right now I use iBuscomM. If I wanna use iBusRR can I just overwrite and that´s it or will I have to spend another 1/2 hour all crunched on my passenger floor trying to figure things out on a 7in screen. (It´s not really hard to set up but not exactly ¨plug and play¨ and the ibus is the only thing you can not setup inside your house since you kinda need your car. I wouldn´t want to mess up my wife´s rug with my bimmer sitting on it...) lol.
    cheers
    at the
    CAR PC NETWORK
  8. #78
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    cheers
    Tell her to wax it off first.
    Now that can be taken one of two ways, which one will you get (that's to all readers not just jeep).
  9. #79
    Sep 2006
    Chevy Chase, MD
    let s just say there´s only one left to be waxed off......
    at the
    CAR PC NETWORK
  10. #80
    Aug 2005
    Canada
    iBusRR is based on iBusCOMM so your ini file will work fine
    the main difference is iBusRR can also send messages to the I-BUS coming from RR
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
