Page 9 of 42 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 413
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
  1. #81
    Constant Bitrate jeep642's Avatar
    Sep 2006
    Chevy Chase, MD
    Besides - iBusRR.exe - and - IBusRR.ini - I need - MSCOMM32.OCX - .
    Is there any other files required to run iBusRR ?
    When you download iBuscomM.zip there´s a whole bunch of files coming with it . Are any of these needed or not?
    cheers
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
  2. #82
    Sep 2006
    Chevy Chase, MD
    I´m working on a skin to use the window/trunk/sunroof open command and I´m also gonna use it through a shuttle xpress (works great in a bimmer, the color matches....), here´s a question :
    can you use 1 button for open AND close command?
    Let´s say I press the front passenger window button and it opens it and once it´s opened the next time I press the same button it´s gonna close it.
    seems to me that´s it´s a toughy unless someone has a workaround.
    It looks like it´s impossible for the iBus to tell RR what the state of the windows are so RR can send the appropriate command... right ?
    Any ideas?
    at the
    CAR PC NETWORK
  3. #83
    Aug 2005
    Canada
    we haven't found yet how to query the car for the status of the windows, so the only way for now would be to use a variable in your skin
    The files coming with ibuscomm are the VB6 run-time files. You'll need them for iBusRR also
  4. #84
    Sep 2006
    Chevy Chase, MD
    @Warfiels : working like a charm !!!
    just 2 things, the rear passenger window doesn't want to get down, probably a typo in the .ini file or something... gonna check it out.
    also, everything works fine except that between each time I press a button I have to wait 2-5 seconds before I can succesfully get something happeningagain, even when I just used one of the RR button and then use the actual window swith of the car.
    Is there a time between each command that you can set up in the .ini file or anywhere else?
    cheers
    EDIT: after doing some research I came along this ¨trick¨: if you remove the ¨01¨ at the end of the codes for the windows you shouldn´t have to wait in between using commands OR console buttons. Has it been verified as working?
    at the
    CAR PC NETWORK
  5. #85
    Jan 2007
    Quote Originally Posted by WaRFiElD View Post
    as soon as I clear up code a bit I'll release the sources, but for now I'm working more on getting my car to run since I got my EWS ****ed up while playing with my secret "I-BUS XECUTER" which basically was trying every possible I-BUS codes based on educated guesses to find how to control lights. I bought a carsoft interface on eBay hoping to me able to resync my EWS with my DME, guess I'll have to wait until I receive it.
    Stay tuned though for my planed "police mode" or "move ****** mode" which is going to flash high beams/corner lights to simulate a police car when people at night aren't moving on left lane, anybody interested to try??
    Were you able to resync the EWS with the DME? Very interested... I've been wondering if this can be done without having to go to the dealer.
  6. #86
    Jan 2007
    New Zealand
    Technically YES it's possible but you have to send a request (probably by spoofing DIS device) and to interpret the answer
    two things that hasn't been found yet (at least not on www.hacktheibus.com nor yahoogroups)
    Why are you guys hunting for these ibus window commands in the dark all the time?
    WiniBus gives you a plain text translation of the ibus commands on the fly, makes it really easy to understand the ibus command syntax
    So grab youself a copy of WiniBus app, plug in the ibus interface, and start typing in ibus codes.
    WinBus will tell you what the code means. On your PC, not on your car.
    Easy, simple, safe, and very very informative.
    PS: you need to know some German!
  7. #87
    Jan 2007
    New Zealand
    The GM sends out window/door status info at regular intervals
    typical msg:
    00 05 BF 7A 51 20 B1
    GM --> GLO 7Ah_TürKlappen offen: Fahrertür Kofferraum ZV: Innenlicht ein
    Bytes 51 and 20 contain bit-mapped info on what door etc is open
  8. #88
    Elsewhere
    Quote Originally Posted by IBusManiac View Post
    You gave your own answer, at least for most of us.
    How about the Wiki?
  9. #89
    Nov 2006
    You need a German? Here it comes ;-))
    Guys,
    as some of you might know, I'm using a different solution for the BMW which integrates with the original factory Nav/Sound/Monitor (CarX), but "we" are always interested in new projects; at the moment some people e.g. are working on an integration of cPos into the original BMW equipment.
    However, if you need some translations between German<->English, just post your questions here, I'm willing to help.
    If there's some interest, I can check this thread regularly (daily), so ...
    cu
    dagezum
  10. #90
    Mar 2004
    New Jersey
    A little help from you i bus experts.. Check out this thread. We are in the middle of getting the DICE HD radio to work via ibus minus the BMW.. this way we have a stable HD Radio solution for everyone..
    Someone here has be be able to crack this HDRadio for the car!
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
