Page 1 of 42 1234567891011 ... LastLast
Results 1 to 10 of 413
Thread: iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
    Aug 2005
    Canada
    Talking iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!!
    It's been a long time since the last release but here it is
    iBusRR v2 NEW AND IMPROVED!!
    Changelog:
    v2.0.5 06/01/2008
    - added $IKEOUTSIDETEMP$ which is outside temperature data (in 'C only) taken from IKE. This should work on all models including those without OBC. The downside is you loose resolution from $OUTSIDETEMP$ (1'C instead of 0.5'C). Update interval is 10sec
    - $OBCSPEED$ and $OBCRPM$ will now get back to 0 when motor is stopped
    - $VIN$ issue corrected
    - new LTS (Light Test Sequence) command. SHOW AND OFF-ROAD PURPOSE ONLY
    v2.0.3 05/16/2008
    - Fixed another hibernation issue
    - added SetGamma=1 into ini file to send NIGHTGAMMA to RR when the lights are turned on and DAYGAMMA when they're turned off
    - added $VIN$ variable
    - added $COOLANTTEMP$ variable
    v2.0.0 (original v2 release):
    - Code has been mostly rewritten from scratch to support easier and faster i-bus messages parsing
    - Each button actions can be configured individually depending of which RR screen you currently are (check the .ini file for more info)
    - !SWITCHSCREENS! command can be used to switch between different user configured screens (again in the .ini file)
    - SENDKEY: can be used to simulate a keyboard keypress instead of sending a command to RR
    - RoadRunner window name can now be changed (might be useful to use in other frontends?)
    - An icon has been added in the system tray to exit program if needed
    - Hibernation support should have been improved
    - Various OBC sensor values are now parsed and sent to RR to be used in your skins
    - IKE time can be synchronized with the PC when iBusRR is launched (SyncTime=1 in ini file)
    Here is the list of currently available sensors (and their variable name in RR):
    $OUTSIDETEMP$ : Current outside temperature, switch from C to F depending on your OBC settings
    $IKEOUTSIDETEMP$ : Current outside temperature data (in 'C only) taken from the IKE
    $CONSUMPTION$ : Current AVG fuel consumption
    $RANGE$ : Range left in your gas tank
    $OBCSPEED$ : Current speed in Km/h
    $OBCRPM$ : Current engine RPM
    $COOLANTTEMP$ : Current engine coolant temperature
    $VIN$ : Vehicule VIN (taken from LCM)
    Light Test Sequence command for your skin (toggle on/off):
    "SENDMSG;iBusRR;LTS"
    As in the last version you can also send pre-defined messages to i-bus using the SENDMSG command in RR
    examples:
    OPEN_TRUNK
    OPEN_SUNROOF
    CLOSE_SUNROOF
    OPEN_DRIVER_FRONT_WINDOW
    OPEN_DRIVER_REAR_WINDOW
    OPEN_PASSENGER_FRONT_WINDOW
    OPEN_PASSENGER_REAR_WINDOW
    CLOSE_DRIVER_FRONT_WINDOW
    CLOSE_DRIVER_REAR_WINDOW
    CLOSE_PASSENGER_FRONT_WINDOW
    CLOSE_PASSENGER_REAR_WINDOW
    The Skin commands to send messages to iBusRR are as follow:
    "SENDMSG;iBusRR;OPEN_TRUNK"
    "SENDMSG;iBusRR;OPEN_SUNROOF"
    etc
    NOTE: You'll need VB6 runtimes files to execute iBusRR
    PLEASE DELETE YOUR OLD .INI FILE AND START WITH THE ONE PROVIDED WITH THE NEW .ZIP FILE
    There is now an LTS.ini file included in the zip file; this is where you can change the light sequence. It is not much commented yet but it should be intuitive to modify. Keep in mind you should not blink your XENON lights as this will shorten the ballast life. Please leave your key to ACC position before sending LTS command. DO NOT TRY WHILE YOU ARE ON PUBLIC ROAD
    My PMs are opened for comments, suggestions and bug reports
    Attached Files Attached Files
    FLAC sama's Avatar
    Feb 2006
    London, UK
    nice one. have a look here BMW IBus-Heads
    there's some code in there to scroll the ibus in the instrument panel, and some code to keep the amp alive. could you include those in there too? would be good for e39'ers!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's pretty cool.. prob. something nice to add to the idrive skin.
    Ride Runner RR's Myspace
    Oct 2006
    California
    car2pc
    I am still a bit new to interfacing with the IBUS - but is the car2pc adaptor compatible with this?
    Aug 2005
    Canada
    @Enforcer: thats EXACTLY the kind of stuff I'm looking for
    Thank you!
    @daregone: if you're able to send and receive commands to the ibus (i.e. ibuscomm) you should be able to do this
    I'm using reslers interface which is working great
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Enforcer View Post
    eh?
    I'll need a E46 to test it out though.
    Didn't say you had to do it.. Just said it would be a nice addition to the "BMW" style skin.. I'd gladly test it if I had one.. hehe
    Variable Bitrate vinzer's Avatar
    Jul 2005
    Montreal, Canada
    What about E53 model ? Is it possible to control it thru the i-bus ?
    BMW X5 Carputer Project
    Finished: 85%
    http://www.mp3car.com/vbulletin/show...lots-pics.html
  1. Wanted, graphic Nvidia PCI (old bus) card !
    By calico in forum General Hardware Discussion
    Last Post: 02-25-2006, 03:55 AM
  2. BMW I/K Bus
    By bmwperson in forum Input Devices
    Last Post: 09-06-2004, 01:47 PM
