Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: iDrive Special Edition 2.20
  1. #31
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by KShoes View Post
    Great Skin, Thanks!
    I'm a noob to all of this so it's probably a noob mistake / something I'm missing. I'm using iGuidance 4 and although the GPS info (sats and speed) are showing in the GPS screen they aren't showing at the top beside the sat and speedo icons. I looked at the gpstop.skin all the iGuidance section looks normal (all other sections are remarked out). This hasn't worked with previous skins also so I believe I'm missing how to enable it elesewhere.
    A workaround is to change the command to the normal format in top.skin and gpstop.skin. DO NOT USE SKINEDITOR!
    Below, only the speedo is working 'cause that's all i want to see for now.
    /[GPS=iGuidance]
    B,152,000,90,045,"GPS",""
    L,190,008,040,025,#Fore#,15,"Tahoma:B","GPSSAT",""
    L,505,004,060,025,128,255,0,12,"Tahoma:B","GPSSPD" ,""
    /L,505,004,060,025,#Fore#,20,"Tahoma:B","GPSSPD""," "
    L,230,008,260,025,#Fore#,15,"Tahoma:B","GPSLON¦¦GP SLAT",""
    /[/iGuidance]
  2. #32
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    So tree, are you saying that if you have #fore# in the line it doesn't work?
    if so check that at the top of the top.skin there is a
    /Define Fore 128,255,0
    make sure there is a '/' at the beginning
  3. #33
    Jun 2007
    The Mile High City
    Ok Guys, This was a test to see if the noob was paying attention, right? The problem appears to be the extra double quote. Did I pass?
    Working fine here now with this -
    L,505,004,060,025,#Fore#,20,"Tahoma:B","GPSSPD",""
    Type slow, I'm old and slow and sometimes forget -- what were we talking about again?
  4. #34
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    GPSLAT, GPSLON and GPSSPD do not show with the #fore# in the line.
    This is what's at the top of top.skin:
    /DEFINE Selected 255,255,255
    /DEFINE Fore 191,164,85
    /DEFINE Contrast 255,255,000
  5. #35
    Sep 2006
    War-Town, GA.
    Extra double quotes? I don't see it!
  6. #36
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    good spot, if that double quote is in the top.skin file ( I don't have one available on this PC to check)then that will be the problem.
  7. #37
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    have a look at the GPSSPD you have / out in your post, plus in my posts above.It is only on the GPSSPD which would explain why that is notworking. However it does not explain then others.
  8. #38
    Sep 2006
    War-Town, GA.
    Aha! I see it now. Had to C&P one on top of the other to tell the difference.
    Thanks KShoes, Enforcer.
  9. #39
    Sep 2006
    War-Town, GA.
    Is it possible to add a shuffle function, or does it already have it? I couldn't find it! (I know where "repeat" is)
    EDIT: Nevermind, found it.
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  10. #40
    Sep 2006
    War-Town, GA.
    "You learn something new everyday"
    If you are running IG3 and wondering why the LAT and LON labels aren't showing, change this:
    to this:
    L,230,008,260,025,#Fore#,15,"Tahoma:B","GPSLON||GP SLAT",""
    Look closely at the double pipes, ain't that something! I just replaced the originals with double pipes from my keyboard and now the labels show-up
    Change the line in the IG section of top.skin and gpstop.skin.
    M2-ATX Power Supply
    Windows XP SP3
  1. iDrive Night Green 2.20 Release
    By Enforcer in forum RR Skins No Longer Supported
    Last Post: 09-08-2010, 10:34 PM
  2. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  3. iDrive for Road Runner - Originally by BTBE
    Last Post: 05-02-2007, 08:07 PM
  4. '03 Toyota Tundra T3 Special Edition
    By techeros in forum Worklogs
    Last Post: 05-26-2005, 07:07 PM
