Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 125
Thread: MMIv2
  1. #91
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    There seems to be a problem loading the MAPPOINT_GPS.skin.
    What is the value of gpsmode in your rr.ini?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #92
    Dec 2006
    Belgium, Lokeren
    Hello Sal,
    A bit late, but here my settings
    Quote Originally Posted by Sal R. View Post
    [GPS]
    gpsmode=1
    mapmonkeypath=Klik hier om path in te stellen
    gpspath=
    gpsname=
    overspeed=55
    gpsport=5
    mappointmap=2
    mapcountry=
    mapcity=
    mapautozoom=false
    isunits=false
    usegpsserv=false
    gasfinderautorefresh=false
  3. #93
    Aug 2006
    Sun Diego
    Quote Originally Posted by BartDP View Post
    Hello Sal,
    [GPS]
    gpsmode=1
    gpspath=
    gpsname=
    overspeed=55
    gpsport=5
    mappointmap=2
    mapcountry=
    mapcity=
    mapautozoom=false
    isunits=false
    usegpsserv=false
    Looks okay.
    Can you please verify that the MAPPOINT_GPS.skin is in the skin folder?
  4. #94
    Dec 2006
    Belgium, Lokeren
    Looks okay.
    Yes, a whole series of MAPPOINT_xxx.skin (7) in the C:\Program Files\RoadRunner\skins\Mmiv2 folder
    I made a clean install, roadrunner and MMIv2, on an other PC and I have the same problem.
    Something wrong with my MMIv2 install file ? (Downloaded it from the first page)
    Do I need to install other skin (supporting mappoint) first ?
    Thanks.
  5. #95
    Aug 2006
    Sun Diego
    Thanks.
    I've been pouring over this and I can't see why it's not loading mappoint_gps.skin. I've downloaded the hosted file and did a fresh install of RR on my dev pc and it worked fine even w/o MAPPOINT installed on my pc.
    Can you post a debug file so I can see what RR is doing when trying to load Mappoint?
  6. #96
    Dec 2006
    Belgium, Lokeren
    Thanks for replying Sal.
    Is there somewhere writen how to create a debug file ?
    I don't know how to do.
    rgds
  7. #97
    Aug 2006
    Sun Diego
    In rr.ini:
    "debugmode=TRUE"
    Save and Close.
    Start RR and then select "Navigation."
    Close RR.
    Go to the RR directory and you should see "debug.txt" in the directory.
    Open it, copy & paste the contents and post it so I can take a look at what's happeneing when hitting the gps button.
  8. #98
    Dec 2006
    Belgium, Lokeren
    debug file
    Attached Files Attached Files
  9. #99
    Aug 2006
    Sun Diego
    debug file
    That is wierd. It's executing the the GPS command, but not loading mappoint_gps.skin. It is loading all commands after "GPS" in the MENU.skin, not MAPPOINT_GPS.skin as intended.
    Okay.
    This is gonna get hairy.
    I need you open the menu.skin file in notepad and change this line:
    Code:
    B10,0,82,87,206,"MMIGPS||MPOPTION1",
    to
    Code:
    B10,0,82,87,206,"GPS",
    Save and start RR.
    This is a check to see if RR's "GPS" command is working. It should load MAPPOINT_GPS.skin w/o any of the buttons working with some labels missing.
    I don't know if you've done this yet, but have you tried opening the mappoint_* .skin files in notepad to see if they are not corrupt in any way?
    Truly puzzling...
  10. #100
    Dec 2006
    Belgium, Lokeren
    I did so but whitout result.
    When pushing left uper "navigation" butom, nothing happens.
    Have verified mappoint_* .skin, all ok and readable
