Great skin! Keep it going. Are going to release the PSD's for people who don't like to leave things alone![]()
Thanks for bump. Back in the swing of things and trying to finish up some skins that are not included so far.
Some updates:
- I've restructured the Utilities menu to remove the "Standard" features and made all the slots user defined. (i.e. If you don't need a web browser, you don't have to have a button for it)
- Modified the select drive menus to include indicators if the drive exists.
- Added new option to add current playlist to an existing playlist in the Audio Playlist Menu.
- New Rainlender skin for a more integrated look.
I'm sure there've been other stuff. That's all I can think at the top of my head atm.
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
Sure..why not? I'll post it up next time I put up an update.
The skin image files are flexible enough for those who want to mess around and can't wait. They are all blank template images that is used and re-used in different skin files. The look and functionality are augmented using the IMG commands.
I used nothing but label codes and patched in .pngs to keep the footprint small.
Hello Sal,
Love this skin.
I'm looking for a skin that best fits the look of my brand new Audi A4 (with the color dig. display between the meters (you know : set 1, set 2, menu) , in place of the red version)
This is the first one who fit : think I will use the white interface, as there is a lot of white also used in this small display
Keep on the good work !!![]()
Thanks for the kind comment. I'll be updating and working on this skin as often as I can to keep up w/ updates, plugins, and new features.
So, I've updated to RRv9-2-2007 on my test machines, and there was a bug using the LOADIMG command. As a result, if you've updated to the latest RR version, you'll find some icons not loading, as well as, the utilities icon selector skin not working properly. Guino is aware and will have a fix for the next release.
Hello,
I downloaded your skin and have the problem, that I canīt see the whole skin. Only a little bit from the left side of the skin. In rr.ini I have fastmode= -1. Could you help?
Ti-ejtsch
I assume you're running at least v4-11-2007?
The only time I've seen what you are describing is running an older version of rr that didn't support GDI+ or an older version of Blue's new RR Config.exe
Do other skins that use backgrounds and tranparencies have the same problem?
