Please go thru the SETUP menu to select your preferences for the skin.
Original Graphics Work by btbe
Designed to work with:
RR v11-4-2007 <- Minimum required!
Winamp 5.13 or version capable of using DJik's
JTFE plugin
Tested to work with:
Silabs USB Radio
HD Radio
iGuidance 3.0
Plugins:
JTFE - DJik
NewHits - Sonicxtacy02
Specturm Analyzer - liquid_smoke
System Manager - quickmic
MP3 Tag Editor - EL CAMINO
Task Manager - EL CAMINO
Updates over beta:
General
- Added specialized VOL+/VOL- to ATT speed volume control that adjusts the max volume using VOL+/VOL- from any screen while att speed is active. Will revert back to orignial functionality when att speed is disabled.
- Incorporated iLists in all Directory and Playlists
Navigation
- Cleaned up track info label placement and are more dependant on Radio/Audio.
Source Menu
- SAVE/RECALL master volume presets when moving thru different media. <-Used to keep the volume from blowing up your eardrums when att speed is disabled. :)
- Added an image uploader script.
- Added a copy playlist to removeable media script defined in skin.ini
- Added a copy track to removeable media script defined in skin.ini
- Removed JohnWPB's iG script call out for general external GPS applications.
- Audio
- - Audio Browser
- - - Modified user drive selection to cylce through connected media using upper L & R buttons instead of using icons for a cleaner look. Media is checked for readiness using the "drivecheck.exe" script.
- - Audio Queue
- - - Removed ID3 Playlist format option from "Setup" and moved functionality into the Audio Queue list.
- - - - Using the L/R arrows will cycle through different pre-formatted PL formats on-the-fly, including the user default setting in rr.ini.
- - - - Holding down either L/R arrows will turn on/off feature that allows MMIv2 to remember the last displayed PL format. NOTE: This feature also uses the $titlesafter$ variable defined in RR.ini to separate ID3 tag data.
- - Audio Playlist
- - - Option to add current queue list to an existing playlist.
- - - Confirmation window to overwrite an existing playlist under the "Save Playlist" menu.
- - - Added playlist browsing functions to see playlist contents in the "Add to" & "Load" playlist menus.
- Video
- - Video Browser
- Radio
- - Cleaned up the Radio functionality
- Added TV
Setup
- Skin-based, trimmed down, RR & Skin Config and moved RRConfig.exe into the Available Utilities Menu.
- Option to use radio art.
- Removed Close Winamp Option from Setup menu.
- Changed static CD drive shortcut into a dynamic configurable drive. All drive shortcuts are now customizeable.
- Added selectable media menu to choose which media is accessible.
- - i.e. If you don't have Sat Radio, you don't have to have it display in the Source Media Menu.
- Restructured the Media Config, Logo, & Att speed config menus for consistency.
- Restructured theme menu to use preview images.
- Removed Master volume preset from iG auto switch
- Added a Plug-In Loader menu
Utilities Menu
- Restructured "Utilities" menu to be fully user defined. Add only the tools or apps that you want.
- RR Picviewer
- - - Holding down either upper L & R buttons will restore default utilities settings.
- Added a Mileage Log skin.
- Added a Maintainence Log skin.
- Added a Delete USB tool - Will clear your MP3s from your removeable media
- TMS
- My Computer - Browse your computer drives & directories. Current capabilites include copy, move, and delete folder/files.
Layout:
Main Menu
- Media Source Menu
- - Audio
- - - Library
- - - Playlist Manager
- - - Queue List
- - Video
- - - Library
- - MPC DVD
- - WinDVD
- - PowerDVD
- - Radio
- - - Function
- - - Presets
- X XM Sat Radio
- X Sirius Sat Radio
- - TV
- Setup Menu
- - General Settings
- - Skin Settings
- - Music Settings
- - Radio Settings
- - Video Settings
- - GPS Settings
- - Phoco Settings
- - Media Settings
- - Source Settings
- - Logo Settings
- - Themes
- - iGuidance Settings
- - Radio Art
- - MP3 Art
- - Attenuated Speed Settings
- - About MMIv2.0
- Navigation
- - iGuidance V3.0
- - Mappoint
- Utilities Menu
- - 14 User-Defined Utility Slots
- - - Available Utilities Menu
- - - - RR Picture Viewer
- - - - Gas Price Finder
- - - - Weather
- - - X Phoco
- - - - CDRip
- - - - Calculator
- - - - System Manager
- - - - Rainlendar
- - - - TS Scribble Pad
- - - - Windows Explorer
- - - - VAG-COM
- - - - MP3 Tag Editor
- - - - Skin Browser
- - - - Web Browser
- - - - File Manager
- - - - Launch
- - - - Notepad
- - - - RRConfig.exe
- - - - Mileage Log
- - - - Maintainence Log
- - - - Gamma
- - - - Clear USB Tool
- - - - TMS
- - - - My Computer
- - - - Task Manager
Application Specific Skins Included:
VAG-COM v3.11-N
MP3 Tag Editor
Souce Media Features:
Audio
- Audio Player
- - Relies on DJik's JTFE plugin to search through the current playlist. Must have a compatible winamp version. I'm using v5.13 and included in the skin are all the files needed to install the plugin. See above for link and more details.
- - Holding down the attenuated speed control button will take you to a config menu to change att speed related options on-the-fly.
- - To access VISU, hold down the mixer button.
- Audio Library
- Audio Queue - Song queue list
- - Subcommands description as follows (L to R): JTFE Search, "SETNEXT" command, MP3 Copy Plugin, Minus 1, Mixer.
- - Add to Playlist - Add current song playing to current playlist to another playlist of your choice.
- - - Left Arrow/Right Arrow to browse playlist contents
- - - Subcommands description as follows (L to R): Add 1 to New Playlist, Add 1 to Existing Playlist, Add Current Playlist to Existing Playlist, Delete Playlist
- - Load Playlist - Load an existing playlist
- - Save Playlist - Save current song queue list to a new or existing playlist
- - - Subcommands description as follows (L to R): Save to New Playlist, Save Over Existing Playlist, Delete Current Selected Playlist
- - New Hits Playlist - Generate a "New Hits" playlist via plugin. Please see above links for more details.
- - Copy Playlist - Copies the contents of the current playlist to a removeable media defined w/in the skin.
Video
- Video Browser
Radio - Works w/ the Silabs and HD Radio Tuner
- Radio Player
- - Three different modes of tuning frequencies using "<<" and ">>". Pressing the "Preset"
button will cycle the modes from Presets > Frequency Tune > Seek. There is an additional "Tune" to bring up OSK to choose a specific radio frequency.
- - "Scan" is a preset scan mode.
- - Does not use an RR standard radio "playlist."
- - Clicking the frequency will add/modify the frequencies "RADIONAME"
- Radio Presets
- - 14FM and 14AM presets
- - Pressing and holding a preset button will save the currect frequency to that preset
Setup MMI Features:
- General - General RR.ini settings
- Skin - Skin related RR.ini and skin.ini settings
- - "BROWSE BY THUMBNAIL" Enable thumbnail view in the Audio Browser & Video Browser skins. A skin setting.
- - "ENABLE iLIST" Turns On/Off iLists (For slower machines, like mine)
- Music - Music related skin & RR.ini settings
- Radio - Radio related skin & RR.ini settings
- Video - Video related RR.ini settings
- GPS - General GPS related RR.ini settings
- Phoco - Phoco related RR.ini settings
- Weather - Weather related rr.ini settings
- Attenuated Speed - Attspeed related RR.ini settings
- Media - Customize all media shortcuts (drive, path, name)
- - When defining drive paths, clicking on the tool/title bar will allow for more options on drive choices (D:\, E:\, etc.)
- Source - Turn on/off source media that you want displayed. (i.e. If you don't have Sat Radio, you don't have to have it display in the Source Media Menu.)
- Logo - Set main menu logo preferences. Useable formats: Flash or Image. Files MUST be located in the skin folder.
- Theme - Select from 6 provided color themes.
- iGuidance - Set RR native IGv3.0 options.
- Plug-ins Menu - Select which plugins you want to enable/disable
- About - Current RR version and notes about current version of MMIv2
Utilities Features
- 14 Open/customizeable slots for external applications or user-defined skins.
- - Currently has 21 readily available user-selectable tools for use. For more details, please see "Available Utilities Menu".
- - - Holding down any slot of the utilities menu will open the list of available utilies for use.
- - Additional Option for user-defined application and associated skin for embedding external programs. No more hand editing a .skin file or ExecTBL.ini. Can be done w/in the skin.
- - Holding down either tool bar L & R buttons will restore default utilities settings.
- RR Picviewer
- VAG-COM - Audi/VW OBD II Scantool
- - Default measuring blocks are provided. These values are entered into VAG-COM using the SENDKEY command.
- - Holding down the numbered "Blocks" will open the NUMOSK to prompt the user for a specific measuring block. After entering a value, the said button will retain those properties until RR is restarted where it will default back to the original value. To change the default value, open skin.ini and edit "Block1-7" w/ the appropriate value.
- - "LOG" button - Also included is the option to open a user defined text file on the local or an external drive.
- - - Holding down the "LOG" button will open a directory browser to allow you to point to a specific TEXT file that will be opened using the notepad editor. In addition, once the file is defined, a TEXT file indicator will notify you if the file exists. Clicking the toolbar will bring additional drive choices (D:\, E:\, etc.).
- - - This feature is most often used to quickly paste fault log data from VAG-COM to the specified text file (located on a removeable media, i.e. thumbdrive) for diagnosis.
- Mileage Log
- - Skin based mileage tracker. Data are saved/recalled from skin.ini with option to save data to fuellog.csv in the root RR folder.
- Maintainence Log
- - Skin based maintainence log. Data are saved/recalled from skin.ini with option to save data to maintlog.csv in the root RR folder.
- - Delete USB Tool - Deletes all mp3's located in any of your specified removeable media.
- - Robby's TMS plugin
- - - Just replace the "tms_1EMPTY.png" & "tms_1ON.png" w/ your appropriate image if youwant to use a custom image for the TMS skin.
- - My Computer
- - - Browse your computers available drives & directories w/ simple functions included: Copy,Cut, Paste, & Delete files/folders. Skin based & uses mycomputer.exe w/ appropriate commands to perform simple tasks.
Included Applications w/ the skin:
- Moffsoft Free Calculator - Has ticker tape feature
- Filemanager
- Touch Screen Scribble Pad
- Skin copy of Notepad
Included Plugins w/ the skin:
- NewHits Generator
- JTFE
I hope I caught everything, but please post if you have issues.
