DOH! It works perfect now! Now, one last question I promise/hope lol. I cannot get the visualization to work. It opens it in winamp, but it does not open in rr.
now i understand what you mean. sorry, but its a long time ago i leave the school.
the problem is very simpel, in every skin folder is a file skin.ini. in this file is written the ADRESS and NAME of the last background skin. this could be different to mine.
if you change the information to your install it will run.
sorry i forget to make notes in my help file about it.
the visu, a book without end.
two are working perfect, the AVS and the MILKDROP. which one you must select under the RRCONFIG file. for other you need the windows_name.
if you use zx3 RRCONFIG its under MUSIC..Page2.
if the visu is UNDER your screen you must install it in the CONFIG of WINAMP.
which way to get a visu without a border, iam looking too.
Very very very good skin,
THE BEST
I have a question whith the clock/speedometer/compass , it don't work for me !!
Do you have a idea ?
Thank
it could be a lot,
at first... have you installed the flash8.ocx fiel ? i think not.
also dont forget to split the gps signal, you need one channel for your navi.. and one for the speedometer, compass.
another thing, which language you use ? did you ever work with swish ?
Hi,
I have flash9e.ocx installed, the screen GPS STAT work fine (With MAZDA but ....)
i see on then menu screen the speedometer and the compas with the real numder of sat but it don't work. I have splited the signal with Xport. I'm use the french language.
( sorry for my poor english)
You understand right ! the number of satellites is showing but the hands of the gauges didnt work ??
I try the flash8.ocx without succes
My screen work under 800x600 !
if the value of the satellites is showing, the var GPSSAT should be work.
that says the setting of the com splitter should be right, otherwise it shows nothing.
what i didnt understand is, the hands of every gauge works with the VAR of RoadRunner. and its not important which language the system is working.
another test for you, in screen menu2 (button left bottom side) is in the mid the tissy clock, speedometer and compass. start and forward by click in the mid. did this application run in your system ?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
