This skin is beautiful, man!!! I love it! When's it going to be released!!!??
SG
its not the simplistique skin, its the 25th version of my iphone one.
by the way.
i want more background screens and made some new under photoshop. if i convert them into .jpg and put them in the background folder for new background, i only get a white background. dont know whats happend with it. i save the files in photoshop into the .jpg format or i convert them under AcdSee. the result is always the same.
is there any help ?
SG
after some changes i got it work , but have can i use coverflow ? and i miss song label .
but it is a nice skin you have make..
volke
for using coverflow, please change in the "Audio_Browser_cover2.skin" in the third line the picture call to
audio_browser2_cover_off.png,audio_browser2_cover_ OFF.png,audio_browser2_cover_DOWN.png,audio_browse r2_cover_down.png.
that was wrong, the source of changing the "RADIO" or "COVERFLOW/Normal" mode is in the exectbl.ini. there please change the line "COVERFLOW","LOAD;audio_browser_cover2.skin" if you want to use COVERFLOW. otherwise leave the 2 behind cover.
what you call songlabel ?
regards
is there the right path to your music folder in the rr.ini ? and did you copy the fonts into windows/fonts folder ? some information you are missing are written under ARIAL and this font is standard in all windows installations. so this you must see.
by the way, the rr.ini (myrr.ini) is only for looking what could be missing like picspath or whatever, NEVER copy it into your install... i think we have different machines and folders.
if i click on a music map , i dont get a list of the song in the map.
and if i will play one music map , it plays all the music map..
but the rest work fine now , had to format my pc , install all program again...
volke
Ride Runner RR's Myspace
sorry, its the roadrunner version of april 07.
(never change a running system)
the field without showing is a DIRECTORY field which shows the information of your musicpath you are selected in your rr.ini. mystical is, that it shows you the great picture of the album but not the small one (SD command).
did other applications run in correct way (show you all information) with your rr.ini ?
