Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 91 to 100 of 186
Thread: Simplistique III, Update 10.Nov.2013
  1. #91
    Jul 2006
    just a heads up. i found a little issue with the gps screen. upon hitting the menu button, it actually exits the gps program (iguidance in my case), and im not sure why its set up that way. anyways i changed the line in the ig_full_screen skin from
    B,11,531,100,66,"CLOSE",""
    to
    B,11,531,100,66,"MAIN",""
    my first official 'recoding' in RR, lol!
    btw what buttons do the code for PREV and MINIMIZE link to?
  2. #92
    Aug 2007
    Hi GF-ler.What font are you using for psd's.In my Windows vista cannot find it
  3. #93
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Trend View Post
    hi,
    its most
    ....HandelGotDBol...
    and
    ...Xirod...
    sometimes
    both fonts are protected by license. i think you find them in the world wide web
  4. #94
    Aug 2007
    thanks for quick reply
  5. #95
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by hari-bhari View Post
    to
    Thanks for that one... I had the same problem with D6 and it's a PITA since I don't know where all the speedcams are without it...
    two things that buggs me is that there isn't any play/pause button except in the audio skin... if I'm listening to my favorite music while at the GPS screen and someone calls I want to pause the music while on the phone without having to go to the main menu and then audio...
    Second thing is that I can't do anything else while listening to the radio... probably just need to change the code on the menu button in the radio skin to something else so that it doesnt mute the radio when exiting... and then add the same code to the audio & video buttons in the main menu so that it mutes it when going to some other screen that has audio...
    Other then that I love it after using it for a couple of days now... nice speed even though I really need to upgrade my CarPC...
    Swedish site for CarPC's
    http://www.bilpc.info
  6. #96
    Aug 2005
    germany
    Quote Originally Posted by Naesstrom View Post
    Mainly Simplistique is selected for IGuidance.
    What kind of Radio you use, Silabs or normal FM ?
    If you lost some Buttons ask for it and i give you an update.
    Give me more help about your install and i'll see to do it, thats a deal ?
  7. #97
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by GF-ler View Post
    I'm using Silabs so I've set it up for use with Iceradio and it's working great... the thing is that in the radio skin the menu button is coded:
    Code:
    B05,8,522,104,77,"radio_mute||EXIT||RESUME",
    and that makes it impossible to use any other screen and listen to the radio at the same time...
    changing this so it doesn't mute the radio when exiting the radio skin and instead add the "radio_mute" in the main menu when entering radio, dvd etc it should do the trick...
    I havn't "lost" any buttons, maybe it's just me that havn't found any way to pause the music in the gps screen/main menu/gps stat, etc... a nice little play/pause button in the bottom row would be real nice...
    don't know what else u want to know about my install, running Silabs, Destinator 6, speedfan etc...
    one small question though, I might have missed it somewhere but how do I set the Background for the skin?
  8. #98
    Aug 2005
    germany
    Code:
    did you ever try to make only the short form "EXIT" ?
    what you are hearing ? if your audioplayer is ON you hear as mainsource the music from your audioplayer... and in the background... low noise... the radio.
    i try it, had the point of kick the USB radio in the air.
    with the changing of the backgroundskin.
    menu2 under SKIN
    Skin opend... Button COLOUR opens the backgroundskin.
    if you make the paths of the BACKGROUNDSKIN and the information inside the rr.ini so as i write.... you see the directory list AND a preview of the selected screen.
  9. #99
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    GF-Ler,
    Are you planning to add "ilist" to Simplistique?
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  10. #100
    Aug 2005
    germany
    Quote Originally Posted by proph View Post
    GF-Ler,
    if i know how it works, perhaps.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
