Page 12 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 111 to 120 of 186
Thread: Simplistique III, Update 10.Nov.2013
  1. #111
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Your doing great work... Thanks for your dedication!
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  2. #112
    Dec 2005
    Sydney
    I've done all the changes you suggested (had them all before) but still no change. I've attached my exectbl.ini just to make sure its all ok.
    Code:
    / SIMPLISTIQUE Extra Commands
    /If your Navigation is different to mine (IG212) please change the... /path to GPS.... and all behind this text
    "iGuidance_ZoomIn","SENDKEY;{up}||GETFOCUS"
    "iGuidance_ZoomOut","SENDKEY;{down}||GETFOCUS"
    "iGuidance_Toggle3D","SENDKEY;{3}||GETFOCUS"
    "iGuidance_Destination","SENDKEY;{ENTER}{ENTER}{ENTER}||GETFOCUS"
    "iGuidance_Orientation","SENDKEY;{3}||GETFOCUS"
    "iGuidance_Menu","SENDKEY;{ENTER}||GETFOCUS"
    "iGuidance_CancelRoute","SENDKEY; {c}||GETFOCUS"
    /Radio selection for ICE/ Silabs..ADS or normal FM Radio
    /"RADIO","LOAD;RADIO_PLAYER_FM.skin"
    "RADIO","LOAD;RADIO_PLAYER_ICE.skin||PAUSE||radio_unmute"
    /PREVIEW BACKGROUNDSKIN
    /For showing the selected Backgroundscreen in a Preview Box
    "TIMER","SETVARBYCODE;LISTTEXT;LISTTEXT||SETVARBYCODE;DLPATH;DLPATH||LDIMG;403;206;263;201;$DLPATH$\$LISTTEXT$;OUT||LOADIMG;403;206;263;201;MainMenu_Off.png;OUT"
    /path to GPS......................................................{ path to your gps application }{ window title}
    "IG212","LOAD;IG_Full_Screen.skin;RUN;C:\Program Files\Destinator\Destinator.exe;!IntellinavWCls!Destinator"
    /"IG212","LOAD;IG_Full_Screen.skin"
    /path to TV.......................................................{ path to your tv application  }{ window title}
    "DVBT","LOAD;tv.SKIN;RUNW;C:\Program Files\TV\TV.exe"
    "PHOCO","Load;freefone.skin"
    "PICS","Load;Picviewer.skin"
    "EXDVD","Load;External_DVD.skin"
    "FMANAGER","LOAD;Filemanager.skin;RUN;C:\Program files\Road Runner\Filemanager\filemanager.EXE;FileManager"
    "PAINT","LOAD;SOLITAIRE.skin;RUN;C:\WINDOWS\system32\mspaint.exe;mspaint"
    "NOTEPAD","LOAD;SOLITAIRE.skin;RUN;C:\WINDOWS\system32\notepad.exe;Notepad"
    "MP3","LOAD;SOLITAIRE.skin;RUN;C:\programme\mp3-tag-editor\mp3tageditor.exe;MP3-TAG-Editor"
    "RRSET","LOAD;SOLITAIRE.skin;RUN;C:\Programme\Road Runner\RRConfig.exe;!ThunderRT6FormDC!RRConfig"
    "COVERFLOW","LOAD;audio_browser_cover2.skin"
    "CVRFLOW_LIST","RUNQ;$skinpath$\coverflow\loadlist.exe"
    "CVRFLOW_SELECT","CLEARLIST||!SELECT||AUDIO"
    "CVRFLOW_UPDATE","RUN;$skinpath$\coverflow\XML\generate_xml.exe"
  3. #113
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    $smol,
    is it possible that you send me
    the USBRADIO.dll which is in your Road Runner folder,
    your rr.ini
    and your menu.skin file
    EXDVD, in the next update its integrated.
  4. #114
    Dec 2005
    Sydney
    PM sent
  5. #115
    Aug 2005
    germany
    this would be the last version of simplistique II in Day and Night mode.
    its with IList, a Play/Pause and a MINIMIZE Button in every Skin.
    Mainly builded for IGuidance with 3 different looks, Full... with Buttons outside.... and half Audio.
    In Audio its possible to see the Albumscover in normal showing, and the way through Coverflow. For Coverflow its possible to selec in the Exectbl.ini between small Coverflow and the last Version.
    The Slider for Volume is no longer, therefore you see the Value between Vol+ and Vol-.
    All Screens... Sirius, XM, GasPricefinder, Mappoint and some other are include with needed .skin files but without function.
    New Clocks are builded WITh the day of the Week showing.
    The Function PLAY PAUSE is an IDEA of Liqiud Smoke and i hope the smiley would be right for this function. Music for the masses.
    now i must go a while with my Dog, after it i give a link in Post1.
    Thats it.
  6. #116
    Jan 2007
    Where do I need to put the 'games' folder in order to get the games to work? I can't seem to get them to load when I set the path to the rr folder, skin folder, anywhere.
  7. #117
    Aug 2005
    germany
    Quote Originally Posted by elimenohpee View Post
    have a look in the games.skin file. in the area ----MID--- you find the adress of the games.
    if the german word ...SPIELE... = Games... is not in your mind, rename all calls to the folder you want.
    otherwise its.... C:\Program Files\Road Runner\Spiele... the wanted folder.
  8. #118
    Jan 2007
    Quote Originally Posted by GF-ler View Post
    I'm sorry I do not see where this 'games.skin' file. I see the folder for the games, but I don't know where I need to change to reroute to the correct folder.
    Also I was clicking around just exploring your skin, and I went to change the color of the skin, and it messed up the background just as if the background folder was not specified in the rr.ini folder. I cannot get it to undo itself. Any ideas?
  9. #119
    Aug 2005
    germany
    yeah you right, ive forgot to write in in the helpfile that you had to build a folder >Spiele< in path C:\Program Files\Road Runner\ ...... and copy the games you want from >games< of the package into this folder.
    the games who are possible are very small. for your favorit games i make empty buttons in the screen. in this buttons you can make your own call of wanted game.
    how it goes ? very simpel..
    this skin has NO colourchanging.
    your problem with the background i didnt understand, maybe my english is to bad.
  10. #120
    Jan 2007
    let me do some screen shots to show you what I'm talking about.
    Follow where the green arrows are pointing, the first image starts at the home page:
    As soon as I clicked change in that last screen, the skin started displaying like it is. Its like it can't find the backgrounds folder, but I didn't change any other settings in the rr.ini.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
