Page 13 of 19 FirstFirst ... 345678910111213141516171819 LastLast
Results 121 to 130 of 186
Thread: Simplistique III, Update 10.Nov.2013
  1. #121
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by elimenohpee View Post
    As soon as I clicked change in that last screen, the skin started displaying like it is. Its like it can't find the backgrounds folder, but I didn't change any other settings in the rr.ini.
    now i understand what you mean. sorry, but its a long time ago i leave the school.
    the problem is very simpel, in every skin folder is a file skin.ini. in this file is written the ADRESS and NAME of the last background skin. this could be different to mine.
    if you change the information to your install it will run.
    sorry i forget to make notes in my help file about it.
  2. #122
    Jan 2007
    DOH! It works perfect now! Now, one last question I promise/hope lol. I cannot get the visualization to work. It opens it in winamp, but it does not open in rr.
  3. #123
    Aug 2005
    germany
    the visu, a book without end.
    two are working perfect, the AVS and the MILKDROP. which one you must select under the RRCONFIG file. for other you need the windows_name.
    if you use zx3 RRCONFIG its under MUSIC..Page2.
    if the visu is UNDER your screen you must install it in the CONFIG of WINAMP.
    which way to get a visu without a border, iam looking too.
  4. #124
    Nov 2007
    Very very very good skin,
    THE BEST
    I have a question whith the clock/speedometer/compass , it don't work for me !!
    Do you have a idea ?
    Thank
  5. #125
    Aug 2005
    germany
    Quote Originally Posted by desert View Post
    THE BEST
    Thank
    it could be a lot,
    at first... have you installed the flash8.ocx fiel ? i think not.
    also dont forget to split the gps signal, you need one channel for your navi.. and one for the speedometer, compass.
    another thing, which language you use ? did you ever work with swish ?
  6. #126
    Nov 2007
    Hi,
    I have flash9e.ocx installed, the screen GPS STAT work fine (With MAZDA but ....)
    i see on then menu screen the speedometer and the compas with the real numder of sat but it don't work. I have splited the signal with Xport. I'm use the french language.
    ( sorry for my poor english)
  7. #127
    Aug 2005
    germany
    Hi,
    did i understand it right, the number of satellites is showing but the hands of the gauges didnt work ?
    if its true, please try the flash8.ocx.
    btw. i forgot something, did your screen work under 800x480 or bigger ?
  8. #128
    Nov 2007
    You understand right ! the number of satellites is showing but the hands of the gauges didnt work ??
    I try the flash8.ocx without succes
    My screen work under 800x600 !
  9. #129
    Aug 2005
    germany
    if the value of the satellites is showing, the var GPSSAT should be work.
    that says the setting of the com splitter should be right, otherwise it shows nothing.
    what i didnt understand is, the hands of every gauge works with the VAR of RoadRunner. and its not important which language the system is working.
    another test for you, in screen menu2 (button left bottom side) is in the mid the tissy clock, speedometer and compass. start and forward by click in the mid. did this application run in your system ?
  10. #130
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Adding the Visteon to my carputer tomorrow... anyone have a hdradio skin yet? If you don't have radio, and you want it this is the piece. My sports talk 1310 (The Ticket) has cd quality sound.
    Trying not to re-invent the wheel.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
