Page 19 of 19 FirstFirst ... 910111213141516171819
Results 181 to 186 of 186
Thread: Simplistique III, Update 10.Nov.2013
  1. #181
    Nov 2013
    I have a question. I had a problem choosing logos. It appears it couldn't find the logos directory especially after I moved the skins up from the skins directory to the Simplistique directory itself so that it matched the structure of Carwings etc. In the logos skin I can get it to work if I replace the $RRPATH$LOGOS with a hard coded path to the logo directory. Where is $RRPATH$ defined so I can modify it appropriately?
    Jim
  2. #182
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by jcmcdougall View Post
    Jim
    hi jim,
    if you worked under windows >XP, copy the folder LOGOS to the path Programme(X86) ......((Programme) is the german name)
    and then in Folder RIDERUNNER.
    please change the skin_browser.skin file. the one in your install is destroyed.
    Attached Files Attached Files
  3. #183
    Sep 2012
    Germany - Munich
    $RRPATH$ is a fix variable in riderunner and is there, where the riderunner.exe exist.
    $SKINPATH$ is a better way
  4. #184
    Mar 2009
    for youtube work on win 7
    thanks
  5. #185
    Nov 2013
    Thank you !
    Yes I did find that the skin browser was corrupted so I just renamed it to be able to load the overall skin in the skin editor. Thank you for the update !
  6. #186
    Aug 2005
    germany
    Quote Originally Posted by achillealb View Post
    thanks
    hi,
    the last i read about the youtube plugin is that its not possible with windows7. they changed the code.
    the plugin from "elcamino" didnīt work for now. i hope elcamino will give us an update in the future.
    regards
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
