Page 5 of 19 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 186
Thread: Simplistique III, Update 10.Nov.2013
  1. #41
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    regsrv32 "C:\program files\Road Runner\GDIPlusWrapper.dll"
  2. #42
    May 2006
    Calgary, Alberta
    spoonfeeding - much appreciated!
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #43
    May 2006
    Calgary, Alberta
    Quote Originally Posted by tn6478 View Post
    I ran CMD to get the command prompt and then typed what you gave me and it told me regsrv32 is not a valid batch file, command or object. I'm running Windows XP with Service Pack 2, not sure what's up.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  4. #44
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Maheriano View Post
    the right order is Regsvr32, in your line are 2 character changed.
    if you write these lines in a NEW .bat file (batch) copy it into the directory where the GDI...dll and all the other .dll are, it goes automaticly.
    @ECHO OFF
    ECHO.
    ECHO Registering the GDI engine so this skin will display properly
    ECHO.
    regsvr32 GDIPluswrapper.dll
    Echo.
    Echo GDIPluswrapper installed press enter for next Step.
    PAUSE
    ECHO.
    EcHO Registering milage.dll and your Tripmeter works
    regsvr32 milage.dll
    PAUSE
    ECHO.
    ECHO Registering screenlock.dll and the password protection will work
    regsvr32 ScreenLock.dll
    PAUSE
    ECHO.
    ECHO Registering RR_ICERadio.dll so you can use the Silabs/Ads Radio Stick
    regsvr32 RR_ICERadio.dll
    ECHO.
    ECHO ....................We are all Spielkinder
    PAUSE
    CLS
    EXIT
  5. #45
    May 2006
    Calgary, Alberta
    Spiel = play?
    Kinder = kids?
    So make a new batch file with this inside, place it in the same directory as the wrapper, and run it? Or don't run it?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #46
    Dec 2005
    Sydney
    lol, yes run it otherwise nothing will happen
  7. #47
    May 2006
    Calgary, Alberta
    I thought the skin might run it itself.
    So I registered the GDIPlusWrapper successfully but I didn't make the batch file. It still won't work. Is there something else in the batch file that's crucial or should it work at this point? Is there a certain place I'm supposed to be putting the images besides just dumping the skin file?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  8. #48
    Aug 2005
    germany
    is there nothing on the screen when you start SIMPLISTIQUE ?
    if there is a small row black/purpur, then you forget to switch on the GDI+ in your roadrunner config file... General/Page2 of ZX3 roadrunner config.
    if you copy the hole path of Simplstique... behind (Program Files\RoadRunner\Skins) into your Skin Folder, it should run.
  9. #49
    May 2006
    Calgary, Alberta
    Ah, never looked at the GDI+ in the config, I'll try that. And yes, I see the single column of black/purple. I must have missed the thread discussing this because I know it's got to be here somewhere.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  10. #50
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I really like the use of transparent white for the buttons, can't top the simplistique layout, and overall looks very well done. Keep up the great work, and thx for the beta code. Oh and one more thing, Are you running a windows server 2008 cluster with all processing power dedicated to video in this screenshot? Album view directory list and the scrolling flash cover shots must have that PC redlined.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 02:20 PM
