I must install this tomorrow. Great work
16:9 (15:9) at 800 x 480
4:3 at 800 x 600
16:9 HIGHER THEN 800 x 480
4:3 HIGHER THEN 800 x 600
Boy these skins are getting harder and harder to modify!![]()
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Make sure that you are using the latest lease of Road Runner or else the skin will not work. The skin is using variables to determine what to images to load. These variable are only supported in the 09/23/08 OFFICAL Road Runner Release.
If you don't use the latest release you will be missing the side buttons in the iG native screen, external navigation screen and the buttons in the video player and dvd player screen.
The first post with the large links that say DOWNLOAD....
Just finished setting up eLite Lite, and what can i say? wow! brilliantly simple and smooth. One thing though, does it have iList support? or do you plan to have it in the full release?
All the best,
-2k
about ilist
Just been fiddling with the .skin files and added a simple iList component:
IL,DL,RGBFF00FF,RGBFF00FF,,2,20,50
It works but there are problems and i can probably guess why he hasn't included it in the skin.
iLists play havoc with the fade transitions and also do not handle fonts at all well. I would hope there is a solution to this by now but i don't think there is.
[EDIT]: I knew guino mentioned it somewhere http://www.mp3car.com/vbulletin/1137852-post2.html
All the best.
-2k
