View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
289. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    115 39.79%
  • 4:3 at 800 x 600
    115 39.79%
  • 16:9 HIGHER THEN 800 x 480
    38 13.15%
  • 4:3 HIGHER THEN 800 x 600
    21 7.27%
Page 23 of 100 FirstFirst ... 13141516171819202122232425262728293031323373 ... LastLast
Results 221 to 230 of 999
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #221
    Tainted Love Cris's Avatar
    Romania
    Is this skin available only in wide screen format? It appears to be so on 800x600 resolution...(
  2. #222
    Low Bitrate Ali_2k's Avatar
    Oct 2005
    Quote Originally Posted by Cris View Post
    It is at the moment. You can try one of two things:
    1) hang about a bit and see if the final release will have both 800*600 AND 800*480, wich is possible but no word from Suavecito yet.
    2) have a go with PowerStrip to add the smaller resolution to your chipset. Its a bit tricky if you have an intel/epia board, but theres some people who have managed.
    Hope that helps
    -2k
  3. #223
    Oct 2005
    Anyone else having a delay with album art/the counter not refreshing when resuming from hibernate?
  4. #224
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Ali_2k View Post
    Just been fiddling with the .skin files and added a simple iList component:
    IL,DL,RGBFF00FF,RGBFF00FF,,2,20,50
    It works but there are problems and i can probably guess why he hasn't included it in the skin.
    iLists play havoc with the fade transitions and also do not handle fonts at all well. I would hope there is a solution to this by now but i don't think there is.
    [EDIT]: I knew guino mentioned it somewhere http://www.mp3car.com/vbulletin/1137852-post2.html
    All the best.
    -2k
    2k is correct about the ilist . I have tryed using it in the past and have had problems with it. That is why I decided to not use ilist in this skin. One thing that I can tell you is that the future release of eLite will not include it either. eLite is a more complex skin and ilist will cause problems with it.
    As for the 800 X 600, it will be a while before I can release in this format.I know that the stretched skin doesn't look as good. Best thing to do right now is to edit the general.ini or change your display settings to 800 X 600 by 75 hertz to get the 800 X 480 look.
    Sorry about that, I am using the 800 X 480.
  5. #225
    Oct 2005
    When you go to general.ini and make it 800x600 the main loading screen for somereason will not change to 800x600 and remains in 800x480 why is that?
  6. #226
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Open the general.ini in the eLite Lite folder.
    Copy the following over the current text in the file and the save it:
    Code:
    OriginalWidth=800
    OriginalHeight=480
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    ApplyToVideo=False
    ApplyToVisu=False
    AutoSwitch=False
    DayTime=8:00:00 AM
    NightTime=6:00:00 PM
    GammaDayRed=1
    GammaDayGreen=0
    GammaDayBlue=0
    GammaNightRed=-40
    GammaNightGreen=-40
    GammaNightBlue=-40
    This should get the skin to fill the screen.
  7. #227
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Keem View Post
    Because the loading screen is shown whilst RoadRunner is loading, this includes loading the information about the skin so therefore RoadRunner doesn't know what size to show the loading skin as it has not yet loaded the info from General.ini of the skin before it displays the loading screen.
  8. #228
    Oct 2005
    Thanks sauvecito on the help...
    Just to be more descriptive on this problem above on resume from hibernate the counter does NOT work unless you press a button and then it will update once and then not work until the next button press.
    For the album art on resume it does not update to the current song properly afterwards, its always one song behind (when hitting next).
    This is only when hibernating from the audio screen.
    I know you are busy with things, Just thought I'd give you heads up.
  9. #229
    Newbie Scorppro's Avatar
    Oct 2008
    Philadelphia, MS
    Just a quick Thank You!!!
    Thank you sauvecito.
    This is an AWESOME skin.
    Looks great and small size.
    I look forward to any other skins you release.
    Scorppro
  10. #230
    Jun 2006
    Having got it to work now, even in "streched" format it is the dogs bollux! clean smooth and fast!
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
