View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
289. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    115 39.79%
  • 4:3 at 800 x 600
    115 39.79%
  • 16:9 HIGHER THEN 800 x 480
    38 13.15%
  • 4:3 HIGHER THEN 800 x 600
    21 7.27%
Page 27 of 100 FirstFirst ... 17181920212223242526272829303132333435363777 ... LastLast
Results 261 to 270 of 999
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #261
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    Quote Originally Posted by mitchjs View Post
    Absolutely fabulous skin!
  2. #262
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by CoronaMike View Post
    Very professional looking skin. I had been using the digitalFX skin for about 1 1/2 years and it was time to change things up a bit. Everything worked great right from the start.
    Suavecito, in sonicxtacy's thread you mentioned you had done a mod to IGiudance.exe to increase the road text and road lines. Do you this available for download somewhere? Or can you describe how you did it. I like using IGuidance instead of the UMPC version but the text and roads are too small.
    Thanks for a great skin.
    Mike its easy to change the text size and road size lines. All you have to do its create a file named THEME.INI, which can be done in notepad and save it to the IGuidance program folder. The theme.ini will only be loaded by the iGuidance.exe and not the iGuidanceUMPC.exe. One of downsides of using the theme.ini is that it will not change any of the menus size, so they maybe a little to small to see. Now, in 2D MODE the theme.ini will effect the text and road lines, but it will not effect the road lines in 3D MODE. Your are going to have play around with the road pen widths for each of the zoom levels until you like it. You can use the theme.ini to change other settings too, for more information on customizing IGuidance visit the GpsPasSion Forums. Note that many of the post say to save to ctheme.ini do not for IGuidance 3 and later, instead save as theme.ini. I have posted an example below.
    In the file you need the following:
    Code:
    ; street name font size in points @ zoom level
    STS=20 20 20 20 20 20 20 20 20 20 20
    ; THE FOLLOWING WILL NOT HAVE ANY EFFECT ROAD LINES IN 3D MODE
    ; IT WILL ONLY EFFECT THE ROAD LINES IN 2D MODE
    ; road pen width in pixels @ 100ft FC1-2-3-4-5
    RPW0=6 6 5 4 3
    ;RPW0=2 2 2 2 1 (default)
    ; road pen width in pixels @ 200ft FC1-2-3-4-5
    RPW1=5 5 4 3 2
    ;RPW1=2 2 2 2 1 (default)
    ; road pen width in pixels @ 500ft FC1-2-3-4-5
    RPW2=4 4 3 2 1
    ;RPW2=2 2 2 2 1 (default)
    ; road pen width in pixels @ 1000ft FC1-2-3-4-5
    RPW3=3 3 2 2 1
    ;RPW3=2 2 2 2 1 (default)
    ; road pen width in pixels @ 2500ft FC1-2-3-4-5
    RPW4=3 3 2 2 1
    ;RPW4=2 2 2 2 1 (default)
    ; road pen width in pixels @ 1mi FC1-2-3-4-5
    RPW5=3 3 2 1 1
    ;RPW5=2 2 2 2 1 (default)
    ; road pen width in pixels @ 2mi FC1-2-3-4-5
    RPW6=2 2 1 1 1
    ;RPW6=2 2 1 1 1 (default)
    ; road pen width in pixels @ 5mi FC1-2-3-4-5
    RPW7=2 2 1 1 1
    ;RPW7=2 1 1 1 1 (default)
    ; road pen width in pixels @ 10mi FC1-2-3-4-5
    RPW8=1 1 1 1 1
    ;RPW8=2 1 1 1 1 (default)
    ; road pen width in pixels @ 25mi FC1-2-3-4-5
    RPW9=1 1 1 1 1
    ;RPW9=2 1 1 1 1 (default)
    ; road pen width in pixels @ 100mi FC1-2-3-4-5
    RPW10=1 1 1 1 1
    ;RPW10=1 1 1 1 1 (default)
  3. #263
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Hey guys,
    Quick update:
    I started to work on the 800 * 600 skin but I've been really busy lately and haven't had a chance to continue work on it. I looks like I will have recreate each of the screens and images and it may take a week or two.
  4. #264
    Jul 2007
    Quote Originally Posted by suavecito View Post
    Hey guys,
    Quick update:
    Can't wait!
  5. #265
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    Hate to rush you but when are we going to see the other colors? I really really need red for my life to be complete.
  6. #266
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    ??? What do you mean ???
  7. #267
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Awesome.
    Are you separating all the icons instead of having them park of the menu? I did this on my modded version so that I could rearrange some stuff and add new icons. I also converted the top bar to an INC so I only have to change it once to update every screen.
    I made some new icons if anyone is interested.
    Camera, Google Earth, Pandora, BMW
    I also made a BMW skin for some Ibus control and gauges and a pandora skin with buttons for thumbs up/down and stuff. If anyone is interested I can post the files if suavecito is cool with it.
    Hey guys,
    Quick update:
  8. #268
    Oct 2007
    Louisville, KY
    blk02si, i was talking about the icons and the items used at the top of the screen. Kelmk also had the right idea, im going to look into that tonight.
  9. #269
    Aug 2007
    SF
    Quote Originally Posted by smp4488 View Post
    It's only one file called on.png that is for the toggle graphics. Just pull it into any photo add and alter the hue to red.
  10. #270
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by kelmk View Post
    Awesome.
    Nice work kelmk,
    I don't mind at all, if you would like for the icons or the screen skins to be included in future releases of elite or elite lite please post the psd and screen skins.
    As for the menu icons, the next version of elite lite uses independent icons instead of a full static image. I am also working on a simple way to allow the user to select what menu button goes where, which will allow for more user customizing, similar to you can do in the DigitalFX 4.0 skin. Now as for more colors, currently that will have to wait, because I have to create two different skins, one 800 * 480 and the other 800 * 600. Once I get the two versions completed I will start to release other color themes.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
