Paint.Net -- http://www.getpaint.net/ -- with the PSD plugin -- http://paintdotnet.forumer.com/viewtopic.php?t=1238
16:9 (15:9) at 800 x 480
4:3 at 800 x 600
16:9 HIGHER THEN 800 x 480
4:3 HIGHER THEN 800 x 600
FYI, the installer worked 'as advertised' when installed to mr Car PC.
Thanks for the skin suavecito - it's great!
Looking foward to the 800x600. In the meantime i'm going to attempt a RRPetrol and Update skin (and accesscontrol) in the Elite lite theme, keeping the Elite logo of course - in appreciation of the work. It appears that Gimp is not able to .psd files as well as hoped. Anyone know of any other free or inexpensive photoshop clones available (PMs welcomed too)?
Many thanks,
Dave
Vauxhall Astra SXi Car PC installed.
I got problems with mapmonkey.
When i choose mapmonkey as my default navigation in RR config it doesn't load in elite when pressing navigation (it does nothing actually).
It does work when i select external in RR Config, but it doesn't embed correctly.
So i changed to Sygic drive now and still testing....
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
Downloaded the paint.net plugin. Thanks mate
Only get a white square with the radio icon button .psd (from post 1) but get the mixer .psd ok. Tried gimp again and that's the same, so Gimp maybe fine with .psd files. Is the icon .psd corrupted? or is there another explanation?
Thanks,
Dave
Ok, i got sygic drive working and embedding just fine
The only thing is that when i press a button, like volume up or down, the navigation screen dissappears and reappears very quickly.
Is this a known problem or am i the only one with this issue?
Add a C line that mimics your A line in the skin file.
ie
A,x,y,w,h
c,x,y,w,h
Just copy the A line in your gps.skin file and change the A to a C then the flicker goes away, then you should have 2 identical lines one with A and one with C. Else
or
in the FAQ.
From the Bible. (Koran or whatever religious book you read)
Originally Posted by SkinCommands.txt
Eh, there's no A line is the GPS skin file??![]()
