View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
289. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    115 39.79%
  • 4:3 at 800 x 600
    115 39.79%
  • 16:9 HIGHER THEN 800 x 480
    38 13.15%
  • 4:3 HIGHER THEN 800 x 600
    21 7.27%
Page 38 of 100 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 999
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #371
    Variable Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    Any news on the 800x600 release?
    Thanks,
    Dave
    Vauxhall Astra SXi Car PC installed.
  2. #372
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    the current ver works in 800x600
  3. #373
    _
    Mar 2004
    Little Elm, Texas
    I just wanted to post up that this skin kicks some major ***. Kudos!
    I've been looking for a RR skin that I liked enough to use in the car and this is it!
    I need to be able to run WinAmp in the car for competition purposes, problem solved now!
    I'll be looking into getting the rest of it all configured now...lol
    Jan Bennett
  4. #374
    _
    Mar 2004
    Little Elm, Texas
    Has anyone managed to integrate iG with this skin using iGNative = True?
    I'm trying to figure out exactly what to change as far as the clip area is concerned.
    I've tried following MatrixPC's post, here, but I'm not getting it...
    Clip area code follow this format C01,XXX,YYY,WWW,HHH.
    Hu?
    The external_gps.skin file code:
    Code:
    RoadRunner Skin
    RRScreen external_gps
    INC,elite/gps/external-$gpsmode$-$ignative$.elite
    INC,font.elite
    IMG,177,28,31,25,"volume.png"
    I,114,439,37,25,"MUTE"
    L,210,32,41,18,51,153,255,12,"HandelGotD","VOLUME","LEFT"
    L,638,2,148,26,181,183,184,18,"HandelGotD","TIME","CENTER"
    L,638,34,148,20,181,183,184,14,"HandelGotD","DATE","CENTER"
    I,556,29,32,24,"SHUFFLE"
    I,588,29,32,24,"REPEAT"
    L04,254,29,299,26,181,183,184,16,"HandelGotD","TAGARTIST","scroll-center"
    L04,177,2,443,26,255,255,255,18,"HandelGotD","TAGTITLE","scroll-center"
    B,12,2,148,55,"MAIN",
    B,638,2,148,55,"NIGHTSKIN",
    IMG,12,2,148,55,"elite.png"
    IMG,12,2,148,55,"elite.png",OFF
    IMG,12,2,148,55,"elite.png",DOWN
    B,90,424,86,56,"MUTE",
    B,1,424,86,56,"VOL+",
    B,179,424,85,56,"VOL-",
    B,268,424,86,56,"PREV",
    B,357,424,86,56,"PLAY",
    B,446,424,86,56,"NEXT",
    B,536,424,85,56,"SHUFFLE",
    B,624,424,86,56,"REPEAT",
    B,713,424,86,56,"MIXER",
    END
    What needs to be changed?
    TIA!
    Jan Bennett
  5. #375
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    IGNative doesn't need the clip region, in fact if you have a clip region you will cut out IG.
    But you do need a application line
    A,x,y,w,h
    Have a look at the include file
  6. #376
    Mar 2005
    Norfolk UK
    Quote Originally Posted by dhantiflag View Post
    Thats how I'm running it at the moment - original 800x480 and show 800x600 .
    I only ask because of using plugins with set sizes i.e. RRpetrol. I lose the bottom of the screen, although I must admit that I have tried the newest version of RRpetrol yet.
    Cheers,
    Dave
  7. #377
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Plugins do not have set sizes, just create images and .skin files to fit into the skin you are using.
  8. #378
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Enforcer View Post
    I guess that want I meant really. As most skins are 800x600, the plugins images and .skin files are good to go at 800x600.
    The elite lite skin author indicated that he was working on the 800x600, which would be fantastic . I just thought I'd ask to see if available yet.
    Regards,
    Dave
  9. #379
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by RedGTiVR6 View Post
    TIA!
    Nothing needs to be changed in the skin, it works out-the-box. Just make sure the setting in RRConfig are correct:
  10. #380
    Feb 2004
    Does anyone have 800x480 skins for picture viewer and gas prices?
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
