Staying with the "lite" theme of things (and since I can't leave well enough alone), here is an addition of
RRGas (US only). This is tested and working the first go around this time
It just has the basic of options: Zip Code search, distance threshold, sort by distance, reload.
Attachment 54331
Install Instructions:
There are 2 sets of files, premodded and if you want to mod your own skin.
Premodded:
Extract all files from the PreMod folder to the eLite skin folder, overwrite all. *note* This also contains a button for the
WiFi-Man plugin... if you want to use that, see the following post for the needed files.
Do not overwrite tools.skin and tools.png from the WiFi-Man install.
Files for WiFi-Man
http://www.mp3car.com/vbulletin/1297320-post394.html
http://www.mp3car.com/vbulletin/1298106-post406.html
DIY
Extract gas.skin, fuel.png, and blist_fuel.png to eLite's skin folder.
Edit tools.png to add gasicon.png as a graphical button.
Use the Skin Editor to add command: "rrgas" to that button.
For both versions, due to licensing agreements, I am not able to include the RRGas plug-in files directly. Those must be obtained from here:
http://en4cer.co.uk/forum
Download from there (registration required), extract to Road Runner\Plugins and run register.exe
Since one of the proposed things for eLite (the full version) is to have RRGas, you'll have to download it anyway, so might as well grab it now.
Support for the plugin must be directed to
this thread.
