View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
289. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    115 39.79%
  • 4:3 at 800 x 600
    115 39.79%
  • 16:9 HIGHER THEN 800 x 480
    38 13.15%
  • 4:3 HIGHER THEN 800 x 600
    21 7.27%
Page 45 of 100 FirstFirst ... 35363738394041424344454647484950515253545595 ... LastLast
Results 441 to 450 of 999
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #441
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by bigbuffs View Post
    I have a Suggestion for Elite II.
    It would be nice to have the option to have the now playing list showing on the main music screen. So instead of having the track info next to the album art you could have the now playing list right there. That way you could scroll through the songs that are upcoming and skip them easier. The Omega has this option and I really like it and think it would be a great addition to your outstanding skin.
    Thanks for the suggestion Big, just to let you know, that as already been added to the eLite Lite II release, you will have a option to display the current way with the the album information only , or the new way with the playlist information. I have also added a restore playlist option to the playlist screen. Every time the current playlist is modified (adding or deleting a song or album from the playlist) the playlist gets saved. It is like an undo option.
    Please keep those suggestions coming.
  2. #442
    Feb 2004
    From post 379: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
    Quote Originally Posted by treetop777 View Post
    Nothing needs to be changed in the skin, it works out-the-box. Just make sure the setting in RRConfig are correct:
    My RRConfig is setup identically to your screenshot, and my iGuidance folder doesn't have a theme.ini, yet some of those side buttons still don't work. The back button, the full screen button, zoom button, and maybe a couple others work, but the ones that interact with iGuidance (menu and destination come to mind) do not function. Any other thoughts?
  3. #443
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Mears View Post
    What version of iGuidance are you using. I used iGuidance 4.0 to test it when I released the skin. It should still work for iGuidance 3.0.
  4. #444
    Newbie Xero's Avatar
    Apr 2006
    Yokosuka, Japan
    Hey, I'm having a bit of a problem with the skin where if I try to use the video or DVD player, media player classic covers the entire screen and I can't get back to Road Runner without closing the video player manually.
    I've tested other skins and none have this problem, any clue what might be causing this?
    I'm using the latest MPC and RR versions.
  5. #445
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Xero View Post
    Looking at it under the microscope (SkinEditor); not sure why the button commands are so complex but i would change them to just "VIDEO" and "DVD" and see what happens..
  6. #446
    Oct 2004
    Israel
    Wow i really love this skin
    is there an estimated release date of elite lite 2?
    im in the proccess of builiding my own car-pc and i would love to customize it to my need , for now im working on 1 but if the release date is soon then ill wait for 2
    thanks alot this is really a great looking skin!
  7. #447
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Ok, I've read this thread and the wifiman related one but still experiencing problems. Maybe something to do with the OS language?
    When I enter the WiFi screen I can't see the right side, it's empty:
    it appears only after that I touch one of the arrows on the left side, but the result is not good!
    Any ideas?
    Quote Originally Posted by Kardain View Post
    I put this together if anyone wants it...
    It works fine on XP. The arrows work as they should.
    If suavecito ever releases the PSD's (or equiv) I can get a couple more buttons added in, but for now, had to cannibalize the skin selector screen for this one, meaning no refresh button.
    Pardon the fuzzy type... apparently this plug-in doesn't work on Vista (see V2 below), so had to remote into my laptop to do the fine-tuning. One down-side, clear type gets disabled. The typeset is fine in the car.
    Plug-in files and premodded skin/image files are included. Any support for the plug-in itself needs to be directed to this thread.
    Both versions are included in the archive file.
    Also, it shows the status as OFF on V1, but it's on.... V2 has the status removed altogether and has refresh/connect/disconnect buttons in its place.
    Enjoy
  8. #448
    May 2008
    Evergreen State
    I'll double check the archive, but it appears you may be using an out of date skin file.
  9. #449
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by l1nk View Post
    Any ideas?
    Just a guess, but I suspect you are not using English, therefore the window title will not be in English, so it will not match the one defined in the execTBl.ini
    look for this line
    "WIRELESS","LOAD;wireless.skin;WIFI;;Wifi Information||SETTOPMOST;RR;TRUE||RUNQW;$SKINPATH$w ireless.exe||SETTOPMOST;RR;FALSE||ACTIVATE;Wifi Information"
    and change 'Wifi Information' to the window name you have.
  10. #450
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Madboy View Post
    At this time I really don't know when the skin will be ready, but hopefully by the end of the month the 800 X 480 will be ready. The 800 X 600 should follow shortly after that. eLite Lite 2 is a complete rebuild of most of the screen graphics and skin files. This is what is currently delaying the release.
    As for you customizing the skin, I don't know what your level of experience is in creating skins. But for a beginner I would recommend eLite Lite 1, for experienced creators I would recommend waiting for eLite Lite 2.
    I can tell you that eLite Lite 2 will be harder to customize if you have no experience with creating skins. The skin works by calling files (INC) and using variables. This is allowing me to create the screens in half the time and allows me to added some more features.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
