Thanks, that should do it. Pretty snappy too on a 1 gigahertz processor.
16:9 (15:9) at 800 x 480
4:3 at 800 x 600
16:9 HIGHER THEN 800 x 480
4:3 HIGHER THEN 800 x 600
This skin is a 800*480, i haven't release a 800*600 yet because of upcoming eLite Lite 2 release. You need to edit the general.ini file in the eLite Lite folder.
See my post here http://www.mp3car.com/vbulletin/1260473-post226.html
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
for the first issue, please make sure your flash is up to date. I installed both the IE and non-IE versions from filehippo.com to get art to work
Don't know which one is necessary for the art, so, better to have more than not enough.
Second issue, no idea. Can't tolerate vis while driving, so never used it.
Macheriano, the skin uses flash to overlay a cd case above the album art. Make sure you have flash installed. If you do not want to use flash take a look at my post here http://www.mp3car.com/vbulletin/1300636-post431.html for a solution.
I don't know what version of winamp you are using. I use winamp 2.95 and haven't had a problem. Make sure you set the correct settings under MUSIC >> PAGE 2 in the RR Config.
example:
if you select MilkDrop make sure you have the plugin installed in winamp directory.if you select AVS Window make sure you have the avs installed in winamp directory.if you select Other make sure you give the window name or else it will not work.
Any idea when the red version will be finished? Definitely looking forward to it![]()
1997 3.8L M5 Camaro: Too many mods :evil:
235RWHP/232RWTQ
I have made the changed to the general.ini file but to no avail. I even changed the resolution using photshop but of course the buttons were off. Short of waiting for the new version to come out is there a way to change the resolution to 800 x 600
the skin very nice i love it, but few issue i can't get it to work. i have updated my Riderunner and adobe flash 10. and changed the skin to 800x600. but when i pressed navigation button my IGuidance not loading up in the small screen all the button on left side is there but blank screen. when i press full screen then it show the map. one more thing how to do i change the front menu option. say i don't want HD radio and fire box there where do i go to change there. i try to press and hold it and it won't let me. i went to setting there wasn't much. please help thank you
