View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 50 of 101 FirstFirst ... 404142434445464748495051525354555657585960100 ... LastLast
Results 491 to 500 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #491
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    patiently waiting eLite lite 2!
    well.. maybe not patiently
    some features to throw in maybe..
    - an "add all music" to playlist.
    - browse by artist, album, title, ect.
    if it had all that, i do believe it would be abslolutely perfect
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  2. #492
    May 2009
    Quote Originally Posted by sk8rjess View Post
    Well, for adding all music to the playlist, why don't you just add all music to a playlist within Winamp, setup the directory to the playlists within RRConfig, and then in eLite you can just select the playlist you just made, and presto! All music will be at your disposal.
  3. #493
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    That was a good idea anarchist. i decided to find a way to automatically create a playlist at startup to search through my media folder as to 'dynamically create' and so that it didn't add any playlists that may be in the directories and add songs twice.
    I came up with this little batch file...
    @echo off
    dir /o:n /s /b *.mp3 *.wma *.m4a *.m4p> Playlist.m3u
    save it in notepad as makem3u.bat and put it in a root location that will see all your music. you can add file types by typing in *.extension where the four are already located. then have the batch file run at start-up to keep it updated.
    I'm not sure how long it will take to be honest. I only experimented with 4 folders. i'll give it a shot when i go home to see how it does with a much larger library.
  4. #494
    May 2009
    Quote Originally Posted by roflcopter View Post
    @echo off
    Well hey, that is an awesome job you did there! Kudos!
  5. #495
    Mar 2008
    Ripon, CA
    Quote Originally Posted by xAnarChisTx View Post
    Thanks!
    I tested it last night with my current library on my carpc and it only took about 10 seconds. unfortunately it had a command window open to do so. I also changed it to send it to a different location so when I set my playlist directory it only picks up that one, not all of the others in the music folders. I suppose alternatively i could've named it _Library.m3u to get it to come up first, but its just the way i went.
    @echo off
    dir /o:n /s /b *.mp3 *.wma *.m4a *.m4p> e:\Playlists\LIBRARY.m3u
    thats the new one.
    Cheers.
  6. #496
    Jun 2008
    Curious Has anyone got Garmin Mobile working with this skin yet? I plan to use this skin but If I can't get Garmin to work then its kinda pointless. I searched the thread but didn't really find anyone actually getting it to work.
  7. #497
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    I have to remmember where to find this - good info!
  8. #498
    May 2009
    Quote Originally Posted by mdawg View Post
    I can gladly say that yes, I have it installed, and it works perfectly. But, in order to get it to work, you need to install the Garmin Mobile PC OSK plugin:
    http://www.mp3car.com/vbulletin/rr-p...e-release.html
    Read up on that, and follow the directions. If you are still having problems, just PM me, and I will set you up with the right files.
  9. #499
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Introducing eLite Frost
    Hey guys quick update:
    eLite Lite 2:
    I am still working on it. It's a complete rebuild in both the code and screens images form eLite Lite 1.2. At this point I don't when it will be released.
    Introducing eLite Frost:
    eLite Frost is the same as the currently released version of eLite Lite.
    eLite Frost is meant for those of you who feel that the black version is too dark or that just need a higher contrast version for daytime.
    There is no newly added features at this point.
    The only difference between eLite Lite and eLite Frost is in the way that it is coded. eLite Frost uses the same code from the unreleased version of eLite which maybe a little complicated to modify if you are a novice at creating skins.
    I am currently testing and putting some final touches on the skin. I will release it within a week, so check back for the download link.
  10. #500
    Jun 2008
    What file do I have to edit in this skin to make Garmin come up?
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 04:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 10:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 03:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 09:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 01:10 AM
