View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 51 of 101 FirstFirst ... 414243444546474849505152535455565758596061 ... LastLast
Results 501 to 510 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #501
    May 2009
    Quote Originally Posted by mdawg View Post
    What file do I have to edit in this skin to make Garmin come up?
    Alright, if you already moved all of the files into the same folder as the eLite skin, then the next step is to edit the menu.skin file within the eLite folder.
    Open up menu.skin, and look for this line:
    B,523,114,251,115,"GPS",
    You want to change that to:
    B,523,114,251,115,"GMPC||GMPC_OVERLAY||RUNGMPC",
    Then save the document, and close out of it.
    Then, with the OSK compressed file that you downloaded with all of the files you need, you should see a .txt document called "Add to ExecTBL ini.txt". What you need to do with this is copy all of the contents within that .txt document into the ExecTBL.ini file within the eLite folder. Just open that .ini file, paste the contents at the bottom, save it, and close out.
    Once you have done all of this, make sure you reload RR, and the next time you are in RR, click on the GPS icon, and it should open up Garmin easily.
  2. #502
    May 2009
    Quote Originally Posted by suavecito View Post
    Hey guys quick update:
    eLite Lite 2:
    I am still working on it. It's a complete rebuild in both the code and screens images form eLite Lite 1.2. At this point I don't when it will be released.
    Introducing eLite Frost:
    eLite Frost is the same as the currently released version of eLite Lite.
    eLite Frost is meant for those of you who feel that the black version is too dark or that just need a higher contrast version for daytime.
    There is no newly added features at this point.
    The only difference between eLite Lite and eLite Frost is in the way that it is coded. eLite Frost uses the same code from the unreleased version of eLite which maybe a little complicated to modify if you are a novice at creating skins.
    I am currently testing and putting some final touches on the skin. I will release it within a week, so check back for the download link.
    This looks amazing! You're really doing an awesome job with this skin!
  3. #503
    Oct 2006
    Need some help with elite
    First of all I really like this skin. Testing it on two systems, xp and vista 32 bit. Almost ready to install my PC into my truck but I'm having one small problem with RR, Iguidance UMPC and elite lite.
    It works perfect on Vista but in my XP system the zoom and 2d/3d button are acting weird. I'll try to explain:
    When I zoom using the plus and minus buttons on the Iguidance screen all is good, but when I try to zoom and change from 2d/3d it locks my mouse cursor and in zoom mode it goes to the max zoom. On 2d/3d it flickers for about 5 seconds then stops. all the while locking my mouse cursor.
    My xp system is the D945GCLF2, 2 GB RAM, 400 GB SATA HD.
    Any clue whats going on? Please keep it simple though, my knowledge of computers is very basic
    Thanks TJ
    Edit: OK both systems are doing this now.....
  4. #504
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    i dont like lighter colors, but frost is def looking good and might be worth a try.
    ps - madina lake, good band
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  5. #505
    May 2006
    Calgary, Alberta
    Wow, Frost looks GREAT! I don't use this skin because the colours are too dark but once the lighter colour Frost is released, I think I'll switch over. If it's done before June 13, I'll be doing demos with it at a big car show.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  6. #506
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by tjbrewster View Post
    Thanks TJ
    Strange, all buttons work good here. Check for a folder elite lite\elite\GPS and see if it there; it contains those commands.
  7. #507
    Oct 2006
    treetop777,
    Checked both systems and that folder contains the same stuff
    Any ideas?
    Thanks TJ
  8. #508
    Jun 2008
    Any update on Frost I can't wait! I kinda wish that the bottom bar was changed tho.
  9. #509
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Update 1: I have made the bottom play bar white also. The screen shots were of the working mock up.
    Update 2: I am currently in the process of making all the main menu screen buttons dynamic. That way the user can change the button configuration order.
    Update 3: It maybe another week before the skin is released.
  10. #510
    Sep 2006
    War-Town, GA.
    treetop777,
    Any ideas?
    Thanks TJ
    Looks good so i don't know. Maybe your version of IG, i have 4.0 and the buttons work fine.
    Hopefully somebody else will chime in with some suggestions.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
