View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 60 of 101 FirstFirst ... 10505152535455565758596061626364656667686970 ... LastLast
Results 591 to 600 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #591
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by suavecito View Post
    I don't know if this will help but, if you leave your screen to 800x600 and then go to your adapter list mode and select 800x600 by 75 hertz (if your card supports it) should give the 800x480 native look while still outputting the 800x600 on the external monitor (I am assuming you are outputting to a 4 x 3 screen).
    DISPLAY PROPERTIES -> ADVANCE SETTINGS -> ADAPTER TAB -> LIST ALL MODES
    Actually the EBY-701 is widescreen. http://cgi.ebay.com/Lilliput-7%22-EB...QQcmdZViewItem But thanks for getting back so quickly!
  2. #592
    Jun 2007
    Minnesota
    Yeah, Garmin support! Too bad no mobilephone.net support yet. I'll download tonight and give it a shot. I love this skin.
    Dan from Minneapolis
    1999 Volvo V70R
    Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
  3. #593
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I think i found a bug in the new version:
    Settings --> Shutdown --> Exit doesn't exit RR.
    I think the problem is that the EXIT command goes back to the prev screen unless it's used in "menu.skin" or "exit_menu.skin", and the new shutdown screen is "shutdown.skin".
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  4. #594
    Jun 2007
    Minnesota
    The method of adding applications to the menu is excellent. Good work on that!
    1999 Volvo V70R
  5. #595
    Jun 2007
    Minnesota
    Quote Originally Posted by Stealth915 View Post
    Yep. The command for that button should be QUIT instead of EXIT and you have to change that in the apps.txt file.
    In apps.txt correct command is:
    /DEFINE APPCOMMAND24 QUIT
    Once you do that, you'll need to restart RR and "reload" the exit button in RR. Hold down the exit button, when the next menu comes up, click more, then click exit. Should work now. The author can correct me if I'm wrong.
    1999 Volvo V70R
  6. #596
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    I have fixed the problem.
    Thanks for letting me know.
  7. #597
    Jun 2007
    I test gmpc, igo by garmincfhelper and igocfhelper but It does not work when I touch on over bar gmpc and igo not work to minimize ( It problem sometime)
    I test on CF it work. Can I fix this problem I like RR I use RR >foobar player>VLC Player>and elite skin
  8. #598
    Aug 2009
    Virginia
    I know you are working on it for eLite 2, suavecito, but is there any chance I could get the skin you have for the mobilephone.net plugin? I tried making one of my own, but it looks like junk. If you haven't done it yet, or just want to wait until it's time for it to be public, I understand. Thanks again for you hard work, it's awesome!
  9. #599
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Spikemonkey View Post
    The main problem that I have with .net mobilephone skin is that I am not able to test it at this point. I do have a layout ready to go but I have not completely skinned it. If you can post what you currently have, it may help with getting something going.
    As for the eLite Lite 2 version it is not compatible with 1.6 and is far from being completed.
  10. #600
    Aug 2009
    Virginia
    Here's what I've done so far with my mad MS Paint skills. It looks like hot buttered hell, I know this, but you asked for it. I can't even take full credit for it, user Wolvers made what I am working off of. It's from post 496 here http://www.mp3car.com/vbulletin/rr-p...plugin-34.html. Thanks again.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
