View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 64 of 101 FirstFirst ... 14545556575859606162636465666768697071727374 ... LastLast
Results 631 to 640 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #631
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by l1nk View Post
    Just installed the august release of riderunner (08/19/09) and still having the same issues. No full screen pictures and no cover in the music player.
    I tried to revert to elite 1.6.5 (leaving riderunner september release) but no success then reverted elite to 1.6 and album covers magically returned! However in this release I have no picture viewer, so no issues on this!
    It seems that the album cover issue is related to the skin itself, not to riderunner. I'd like to know if there's someone who have this feature working correctly.
    Also, going back between releases I saw again the great work you've done to enhance your skin! Thank you again for share it
    Are you getting a greybox for the albumcover? If you are this becuase it is using flash. Simply remove the flash line in the audio player or try installing flash.
  2. #632
    Low Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by Spikemonkey View Post
    Ok, so THAT'S why it isn't working loading the ID3 info until I restart. Does anyone know a program to create a playlist with a definite instead of a relative path? Winamp, Windows Media Player, and MediaMonkey all use relative. I tried using Find and Replace in Notepad, but with a 12,000 song playlist, it would take a few months just to update one list. Thanks again!
    Nevermind, I found one! DioneSS playlist editor, it works great!
    OK, scratch that DioneSS is secret shareware. Does anyone have any ideas?
  3. #633
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by suavecito View Post
    No, I haven't the graybox, I have latest flash installed!
  4. #634
    Sep 2009
    yeah my album art is the same too. i have the latest flash still no art.
  5. #635
    Mar 2006
    How do I get GMPC mobile to work? I changed the button using the long click method and have GMPC installed. Do I need to install the overlay plugin? Any details would be great! Thanks!
  6. #636
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by guino View Post
    This issue has been identified and fixed (next release) -- only happened if you use the mp3art plugin.
    Hi Guino,
    Is it possible to the an album art in any skin whithout this plugin ?
  7. #637
    Jun 2007
    i have touchscan program and i want add to skin
    i use this command
    "LOAD;touchscan.skin||RUN;e:\Program Files\touchscan\touchscan.exe",
    but i do not like border can i load skin without border of program same nodpad IE and calculator and fix screen
    please suggest me Thank you
  8. #638
    Jun 2007
    Really really good job....it's a very functional skin...
    one question...
    in the music section, i couldn't see the album's image...i have 1 image in every album folder. i've to rename the jpg file which are in the albums folder with some particular name??
    ELITE LITE 2 HAS NOT BEEN RELEASED AND IS NOT COMPLETE YET[/B]
    when do you think to release this version?
  9. #639
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by anuchit View Post
    i use this command
    try putting the window name at the end ie.
    "LOAD;touchscan.skin||RUN;e:\Program Files\touchscan\touchscan.exe",touchscan
    i'm not sure if it goes in or outside the quotes
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  10. #640
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Jeegro View Post
    FOR THOSE OF YOU WHO ARE HAVING PROBLEMS WITH THE ALBUM ART MAKE SURE ALL SETTINGS ARE CORRECT IN THE RR CONFIG PROGRAM. TAKE A LOOK AT THE IMAGE BELOW. ALSO TRY DOWNLOADING THE PATCH ON POST #1.
    Quote Originally Posted by tommy_xx84 View Post
    AT THIS POINT I DON'T KNOW WHEN I WILL RELEASE IT. ELITE LITE 2 IS A COMPLETE REBUILD OF ALL THE SCREENS AND IMAGES. SO IT MAY BE A WHILE.
    Quote Originally Posted by matrix607 View Post
    NO PLUG-INS ARE NEED TO GET GMPC TO WORK. JUST CLICK ON THE DYNAMIC MENU BUTTONS AND SELECT GARMIN PC. THATS IT.
    i use this command
    ANUCHIT, THE FOLLOWING CODE SHOULD WORK.
    "LOAD;touchscan.skin||RUN;e:\Program Files\touchscan\touchscan.exe;touchscan"
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
