View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 70 of 101 FirstFirst ... 20606162636465666768697071727374757677787980 ... LastLast
Results 691 to 700 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #691
    Oct 2004
    Israel
    l1nk
    if you got it working with autohotkey why not just use it?
    also did you try autoit script?
    for me it did better job at things like that than sendkey / autohotkey
    also in autoit you can compile it to exe then run it in rr easily..
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  2. #692
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by Madboy View Post
    l1nk
    Autohotkey works correctly when I use it manually; if I put the SENDKEYcode to trigger autohotkey in a RR skin button it simply fail!
    Autohotkey also let you compile your scripts to exe and I used my compiled script for testing. Why autoit is better? You did control succesfully some embedded application with autoit?
  3. #693
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have the same sendey key problem with an autoit script who send sendkey to RR .
    I said to Guino that my sendkey don't run, He answer me that senkey is not full complet in RR .
    May be in a last RR release !!!
  4. #694
    Oct 2004
    Israel
    Quote Originally Posted by l1nk View Post
    i used it for some other stuff..
    the compiled autohotkey not working good for you?
    i haven't used autohotkey much but i think autoit script might be better
    just use :
    Code:
    WinActivate ( "ZSNES" )
    Send("p")
    see if works
    another thing you can try is maybe using kanakey ( running it from inside rr or using it to call autohotkey or whatever you want )
    http://www.kanasolution.com/index.ph...pid=2&utilid=5
    good luck
  5. #695
    Jun 2007
    Sardinia Island
    just use :
    Code:
    Send("p")
    see if works
    good luck
    Tried AutoIt with the four SEND commands and "runq" on every skin button. It works but I needed to add a delay on every keystroke, maybe a zsnes related issue.
    Thank you all for suggestions.
  6. #696
    May 2008
    Bordeaux, France
    Do you have an exemple of your autoit script please ?
    Jun 2007
    Sardinia Island
    I forgot to say there's another little issue on my zsnes skin. I'm sure you all know how to solve, so tell me!
    In the roms browser when I choose the rom then play SELECT button all goes right.
    If I select the rom using a double tap on screen (i.e. double click on the list) then the selected rom is loaded by winamp...
    I'm not so good with lists but I think it's a standard behaviour for this object type, I just need to know how to change it and execute the command sequence as in the select button!!
    Pls help!
  8. #698
    Jun 2007
    Sardinia Island
    Quote Originally Posted by pierrotm777 View Post
    Sorry, I forgot to put these in my previous post.
    Quit ZSNES:
    Code:
    Opt("SendKeyDownDelay", 50)
    Send("{ESC}")
    Open State:
    Code:
    Send("{F4}")
    Save State:
    Code:
    Send("p")
    Pause game:
    Code:
    Send("{F2}")
    I put the 4 executables inside a Zsnesw folder inside the RR plugins folder and every button on the nintendogame.skin have a RUNQ command as follow:
    Quit
    Code:
    "RUNQ;$pluginspath$Zsnesw\quit.exe||EXIT"
    Open
    Code:
    "RUNQ;$pluginspath$Zsnesw\open.exe||EXIT"
    Save
    Code:
    "RUNQ;$pluginspath$Zsnesw\save.exe||EXIT"
    Pause
    Code:
    "RUNQ;$pluginspath$Zsnesw\pause.exe||EXIT"
    Attached to this post you'll find every file (I hope!) needed to have the zsnes skin working.
    The zsnes program folder is located inside the RR root folder. The roms are elsewhere.
    You need to change the rom's path inside the skin.ini and add a button on your entertainment screen to call the nintendo.skin screen. I've included the zsnes png icon I've created and I'm using on that button.
    Any doubt, just ask me!
    Attached Files Attached Files
  9. #699
    May 2008
    Bordeaux, France
    Quit ZSNES:
    Code:
    Send("{ESC}")
    Open State:
    Code:
    Send("{F4}")
    Save State:
    Code:
    Send("p")
    Pause game:
    Code:
    Send("{F2}")
    Quit
    Code:
    Open
    Code:
    Save
    Code:
    Pause
    Code:
    Thanks Thanks thanks ...
    I try that as soon as .
  10. #700
    Jun 2007
    I want to change MUTE volume to ATT
    Anyone please suggest me about it to change command
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
