View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 71 of 101 FirstFirst ... 21616263646566676869707172737475767778798081 ... LastLast
Results 701 to 710 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #701
    Registered User
    Jun 2008
    Question
    Hi,
    How to add flash object to the skin in ver. 1.6.6.
    I can see flash object in the skin editor 0.76 but is invisible when run RR
    I would like to add spinning logo in main menu.
    I using newest RR and flash player plugin.
    Thanks for any advice
  2. #702
    Oct 2006
    denmark
    Quote Originally Posted by tommy_xx84 View Post
    ok...this is how i've fixed the garmin problem for the moment...i'll hope with the elite2 it'll be fixed...
    is only for 800x600 resolution, because i haven't psd files of the skin..., and garmin is better embedded with 800x600 resolution
    here you can find the zip with the .png, .skins and other to fix the problem
    http://www.megafileupload.com/en/fil...-Lite-rar.html
    in OSK screen the character "," "/" ";" "|" dosen't work,and "shift" and "Caps Lock" were changed in "left" and "right"
    the character will be type only in lowercase
    enjoy
    cant get it work right , gamin size is to big , cant see the top of
    elite skin and orly half of the bottom of the elite skin ?
  3. #703
    Jun 2007
    your video setting are 800x480!?!?!
    if yes, my fix is only for 800 x 600 resolution....
    if you have already 800x600 resolution, check if you have override the files correctly, because i'm using this skin in my car and it works fine....
  4. #704
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Has anyone completed a Elite lite RRGas or RRUpd8 skin? If so, would it be possible to havea copy?
    Thanks....
    Vauxhall Astra SXi Car PC installed.
  5. #705
  6. #706
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Enforcer View Post
    Why would you want Gas?
    I don't, I want RRPetrol skins in Elite lite theme but I was thinking of the majority forum base and talking the language that would get more response. RRGas and RRPetrol must be virtually identical as far as skins go, surely...
    I'm really liking the Elite lite skin theme and have got new mobo etc. which I'm hoping to get all the features I've been thinking of adding but too lazy to do thus far. I need to revisit the icons again to get this sorted once and for all! (or as sorted as it can be.........)
  7. #707
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Davefocus View Post
    Sort of.
    Depends on whether the RRGas screen is done with the new RRGas in mind or the old Gaspricefinder in mind.
  8. #708
    Mar 2005
    Norfolk UK
    Help required please with my Dashcommand obd.skin to get Dashcommand to embed just as Sygic embeds.
    I've effectively copied the elite>gps folder and renamed it to obd, keeping other and other-1. I also copied the eternal_gps.skin and renamed to obd.skin and changed the skin line to INC,elite/gps/$gpsmode$$viewmode$.elite to INC,elite/obd/$gpsmode$$viewmode$.elite
    Lastly I've added LOAD;obd.skin||RUN;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand to my run command in apps.txt
    Obviously this doesn't work but can anyone advise me where I've gone wrong. I've messed around so much with it I've lost focus on what I'm trying to do with it....
    Many, many thanks.
  9. #709
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Many, many thanks.
    try
    LOAD;obd.skin;OBD;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand
  10. #710
    Mar 2005
    Norfolk UK
    try
    Thanks E. Spot on.
    Next stage to is to refresh myself with RRPetrol and RRUpd8 and develop some Elite Lite Themed skins
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
