View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
289. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    115 39.79%
  • 4:3 at 800 x 600
    115 39.79%
  • 16:9 HIGHER THEN 800 x 480
    38 13.15%
  • 4:3 HIGHER THEN 800 x 600
    21 7.27%
Page 74 of 100 FirstFirst ... 24646566676869707172737475767778798081828384 ... LastLast
Results 731 to 740 of 999
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #731
    Feb 2006
    Quote Originally Posted by Enforcer View Post
    No, it's just on button command
    Hi Enforcer,
    Thanks for your reply.
    Do you mean that you disable the dynamic menu and set one dedicate button to the command? That is, instead of command "$MENUBUTTON02$" for instance,
    I can have the command as "LOAD;games.skin;RUN;C:\Program Files\Mobile Impact\me.exe;Mobile Impact||PAUSE"?
    Thanks in advance!
  2. #732
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I'm not using this skin, I was referring to what I have done in my iDrive skin.
    But try replacing the dynamic button with that command and see if it works, it could help work out whether it is the command or the way the dynamic buttons work that is causing the issue.
  3. #733
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Quote Originally Posted by suavecito View Post
    The full-screen image viewer is completed. The reason that no button is shown in the pictureviewer.skin has to do with the fact that it is included the .elite file that it loads.
    If the file is not loaded, you will not see your images, and it will not list any images in the list. I believe I have solved the problem you have had using it. I will release it in the next release which should be out this by this weekend.
    I'm still having the full screen pictures issue. No one else have this problem? Pictures list works ok and preview works too but when I select the full screen button I only get a black screen.
  4. #734
    Feb 2006
    I tried to replace the dynamic button command with the command I used in DFX 2.0, and it works.
    Only one problem left," play||exit" always starts my paused music from the beginning. How can I play the song from where I paused it?
    Thanks in advance!
  5. #735
    Feb 2006
    Quote Originally Posted by l1nk View Post
    I have the problem too. Still wait for solutions~
    Also, I have the blank screen issuse as well sometimes on my video playing.
  6. #736
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Confirmed. Happens after installing the patch. Before the patch, no matter what picture u highlight (it does display the picture selected), only the first one in the list goes full screen..
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  7. #737
    Jun 2007
    i'm trying to fix it....at now i could load the selected image at full size, but not do next or prev....
  8. #738
    Nov 2009
    is there a way to change the visuals to something other than this in music: Also, my album art is not working. I tried to install flash player and it did not install right - maybe because this computer has windows 7 don't know. I also downloaded and copied the other music skin that doesn't require flash and this didn't fit it either. Any other ideas?
  9. #739
    Aug 2007
    suavecito,
    I appreciate your work, very impressive.
    Is there a way I can add menu items to the skin and yet still keep the dynamic menu feature? ie, How can I add more options to choose from when selecting menu items through the press and hold dynamic menu. I am looking to add some custom apps, wifi, gas, etc
    Thanks!
  10. #740
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Go to the elite lite folder and find the apps.txt file.
    Open with a text editor and follow the instructions in the file.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
