View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 76 of 101 FirstFirst ... 26666768697071727374757677787980818283848586 ... LastLast
Results 751 to 760 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #751
    Mar 2009
    Can't wait any longer, this skin rocks!
  2. #752
    Constant Bitrate Spikemonkey's Avatar
    Aug 2009
    Virginia
    Quote Originally Posted by Spikemonkey View Post
    I just had to get a new carpc system so I finally updated my Riderunner from the July release to the latest. Now, next to my phone numbers on the mobilephone.net screen, are icons that look like the default windows video file ones. Is there anyway to get rid of these? Thanks.
    Soooo...no one has any ideas?
  3. #753
    Nov 2008
    BTW: If anyone has found that the / key on the OSK is not working for them then the skin command is missing a close speech marks "
    Other than that it's a sweet skin!
  4. #754
    Nov 2009
    Any idea why the equalizer/mixer doesn't work. I was using windows media player but now Ihave my settings set to use winamp. I have searched and can't find the answer. The bass and treb are all the way down. If I use any of the presets, it doesn't change anything.
  5. #755
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Joshc8503 View Post
    Josh, the reason that you do not get the Bass and Treble sliders has to do the your audio card not being supported. As for the presets, the skin does not come with any presets. You have to create them and save them yourself. Also make sure your Equalizer is on in Winamp.
    Spikemonkey, I know that this was a problem in the last release. It showed the icons even when you told it not to. Supposedly the problem was correct in the latest release. You could try adding a SD command to the screen and see if that works.
  6. #756
    Aug 2009
    Virginia
    Quote Originally Posted by suavecito View Post
    How do I go about adding an SD command? I am not familiar with what that is.
  7. #757
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Spikemonkey,
    I figured out the problem. It has to do with skin.
    Download the attached file, rename to mobilephone.skin and replace in the eLite folder.
    Attached Files Attached Files
  8. #758
    Aug 2009
    Virginia
    Spikemonkey,
    Will do. Once I get the chance, I will change it out and let you know the results. Thanks!
  9. #759
    Jan 2007
    i have problems with GMPC on 800x600
    here is the picture, GMPC windows is about 20pixels to high and i cant see the strret names.
    oh yes, virtual keyboard is not working too, it just wont show up
    how can i solve these problems?
    btw. this is the best skin for RR if u ask me
  10. #760
    Sep 2005
    Agreed this skin is awesome!
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
