View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 78 of 101 FirstFirst ... 28686970717273747576777879808182838485868788 ... LastLast
Results 771 to 780 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #771
    Nov 2003
    Connecticut
    can you tell me what font was used to make this skin? im trying to make a skin for OBD tools, but i need to know what font was used
  2. #772
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by CTdubbin View Post
    I use the HandelGotDLig.ttf font. The font gets installed when you install the skin. You can find it in your windows font folder.
  3. #773
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by suavecito View Post
    You need to use a plug-in like Mp3Art.
    1. Download the patch: eLite Lite Mp3 Cover Art Patch.exe
    2. Install
    Thanks for this...
  4. #774
    Aug 2008
    Okey so i've got this bug with elite and Garmin PC.
    Is it win7 to blame ? This is just my test - rig , my carpc uses win xp..
    Any ideas ?
  5. #775
    Low Bitrate dLockers's Avatar
    Jul 2007
    Hi pir4t. All you need to do is is open RR config and select remove windows toolbar when open. It is a Win7 bug but easily solved by that setting> I use Win7 as my main carpc OS now so deffo fixes it.
  6. #776
    Jan 2010
    Ohio
    Okay, This is my first attempt at embedding, and I'm trying to embed DashCommand into eLite. I've been able to run it through the applications tab but I want to make it run through its own button. I've managed to get an obd button onto the tools screen. I copied the audio_visuals.skin and renamed it to obd.skin. When I click on the obd button it does go to the new obd.skin but no program starts running.
    This is the part i'm unsure about, i've went in to the apps file and in the define appscommand29 line it has
    LOAD;obd.skin;OBD;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand
    Did I miss a step somewhere, i've searched and can't seem to find an answer. Thanks for any help!!
  7. #777
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by Slider1385 View Post
    The best way to add is command is to add it to the ExecTBL.ini. The problem is that the command is not being saved to the skin.ini. Try the following:
    1. Add the following somewhere in the ExecTBL.ini:
    Code:
    "Dashcommand","LOAD;obd.skin;OBD;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand"
    2. Replace appscommand29 line in the apps.txt with:
    Code:
    /DEFINE APPCOMMAND29 Dashcommand
  8. #778
    Jan 2010
    Ohio
    I'm still having a bit of an issue. It now says dashcommand not found and won't load anything. I copied the line into the exectbl file, I just put it on the bottom, I attached the file of what it looks like, is there a different place I should have put it? Thanks a lot for your help!
    Attached Files Attached Files
  9. #779
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    The placement shouldn't matter. I have tested this and it works.
    1. Try the following command in the EXECTBL file:
    Code:
    "Dashcommand","LOAD;obd.skin||RUN;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand"
    2. Clear the Dashcommand button from your menu
    3. Make sure you replaced the appscommand29 line with:
    Code:
    4. Add it to your menu
  10. #780
    Jul 2008
    CA
    First of all thanks suavecito for this beautiful skin, have to be one of the best piece of art around. Thanks again.
    Now this is for any one who can help, I'd tried to look for info on this, but can't find a solution. If it had been done already, please accept my apologies, hate it when the light at the end of the tunnel is just a 90 degree with 2 steps away. Well here goes, I been trying to incorporate the Safely Eject USB devices as a button, but can't seem to do it. With eLite Lite skin, it allow me to add a button, but how do I refer it to the actual application of Safely Eject USB Devices. Thanks in advance for any assistance or point in the general direction.
    PoWdEr9K
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
