View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 79 of 101 FirstFirst ... 29697071727374757677787980818283848586878889 ... LastLast
Results 781 to 790 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #781
    Variable Bitrate egeekial's Avatar
    May 2004
    Will eLite 2 support Garmin Mobile PC with 800x480?
  2. #782
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    Quote Originally Posted by Powder9k View Post
    First of all thanks suavecito for this beautiful skin, have to be one of the best piece of art around. Thanks again.
    Now this is for any one who can help, I'd tried to look for info on this, but can't find a solution. If it had been done already, please accept my apologies, hate it when the light at the end of the tunnel is just a 90 degree with 2 steps away. Well here goes, I been trying to incorporate the Safely Eject USB devices as a button, but can't seem to do it. With eLite Lite skin, it allow me to add a button, but how do I refer it to the actual application of Safely Eject USB Devices. Thanks in advance for any assistance or point in the general direction.
    PoWdEr9K
    shortcut for safely remove program app. probably just embed it? dunno, dont skin much.
    %windir%\system32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
  3. #783
    Jun 2007
    St. Louis
    ok - first let me appologize if this subject is covered in the thread elsewhere, I've been doing some searching and have yet to come across an answer (been at this for a few hours now).
    I'm trying to run this skin and utilize both Garmin and iGuidance - with Garmin as the primary GPS program.
    I've read about the Garmin Compatability and have already downloaded and installed the patch2. However, in the skin when I try to run Garmin, it loads iGuidance. If I load iGuidance, iGuidance loads. I've looked in the various .cfg files and skin files, but I'm not fluent in skinning and haven't come to any resolution yet.
    Any ideas or how do I fix this? This skin is sweet and this is my only holdup.
    Thanks in advance.
    :EDIT: - I might also add that iGuidance is installed on the c:\program files location, while Garmin is installed on D:\GarminMobilePC (limited space on c:\)
  4. #784
    Newbie RockWilder's Avatar
    Nov 2009
    PoWdEr9K
    Don't know if this will help you out (Powder9k). You can create a shortcut and then try executing from the skins exec table. Just right click on your windows desktop and select new shortcut....paste the following in.....RunDll32.exe shell32.dll,Control_RunDLL HotPlug.dll
    Double click the icon and it should bring up the "safely remove hardware" box.
  5. #785
    Aug 2008
    Quote Originally Posted by dLockers View Post
    Hi pir4t. All you need to do is is open RR config and select remove windows toolbar when open. It is a Win7 bug but easily solved by that setting> I use Win7 as my main carpc OS now so deffo fixes it.
    This is what i get by removing taskbar :
    As you can see, Im still missing the "navigation" menu .
    Ie , i cant exit the .skin file , i can exit GMPC but im left with a blank screen then.
    EDIT : As you can see im having riderunner set at 800*600 , with the 800*480 skin.
    However changing the resolution in RRconfig doesnt have any effect on GMPC , i still get it "too long" and slightly to the right.
  6. #786
    Jul 2008
    CA
    Just a thought on the background setup.
    Hello everybody,
    I just have a thought, hope this don't get me into trouble . Is there a way to automatically change the background in Elite, using either at a certain time or interval? I think that this would greatly resolve the problem of manually turn down the brightness and contrast everyday. What would be you guys input on this thought? Thanks advance for any feedback.
    PoWdEr9K
  7. #787
    Aug 2005
    trying to embed an application. should i be modifying the apps.txt file?
    would this be the right format?
    /DEFINE APPCOMMAND29 LOAD;efilive.skin;C:\Program Files\EFILive\V7.5\EFILive_Scan.exe;EFILive Scan V7.5
    What else needs to be done? when I click on my button I just get the modified musicplayer.skin I eliminated all the buttons from with the skin editor and renamed efilive.skin
    my app never gets launched. I am new at this so be kind please
    Thanks in advance!
    Heath
    First Carputer in progress.....
  8. #788
    Oct 2004
    Israel
    WillyWonka -
    Just a few posts above there is you answer :
    Quote Originally Posted by suavecito View Post
    The placement shouldn't matter. I have tested this and it works.
    1. Try the following command in the EXECTBL file:
    Code:
    "Dashcommand","LOAD;obd.skin||RUN;c:\Program Files\Dashcommand\Dashcommand.exe;Dashcommand"
    2. Clear the Dashcommand button from your menu
    3. Make sure you replaced the appscommand29 line with:
    Code:
    /DEFINE APPCOMMAND29 Dashcommand
    4. Add it to your menu
    Just modify this to fit your app and you are done
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  9. #789
    Aug 2005
    thank you sir.
    will give it a try tonight.
    Heath
  10. #790
    Aug 2005
    getting it to launch now but it does it outside of the skin???
    would that be me defining the window name wrong? the window name is the one on the end of the command yes?
    "EFILIVE","LOAD;efilive.skin||RUN;C:\Program Files\EFILive\V7.5\EFILive_Scan.exe;EFILIVE Scan V7.5"
    Heath
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 04:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 10:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 03:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 09:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 01:10 AM
