View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 80 of 101 FirstFirst ... 30707172737475767778798081828384858687888990 ... LastLast
Results 791 to 800 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #791
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by WillyWonka View Post
    getting it to launch now but it does it outside of the skin???
    would that be me defining the window name wrong? the window name is the one on the end of the command yes?
    "EFILIVE","LOAD;efilive.skin||RUN;C:\Program Files\EFILive\V7.5\EFILive_Scan.exe;EFILIVE Scan V7.5"
    I HAVE TESTED THIS CODE AND IT WORKS:
    1. DOWNLOAD AND RENAME THE EFILIVE.TXT TO EFILIVE.SKIN AND PASTE IN THE ELITE FOLDER.
    2. Try the following command in the EXECTBL file:
    Code:
    "EFILIVESCAN","LOAD;EFILIVE.SKIN||RUN;C:\Program Files\EFILive\V7.5\EFILive_scan.exe;EFILIVE SCAN V7.5"
    3. Clear the EFILIVE button from your menu
    4. Make sure you replaced the appscommand29 line with:
    Code:
    /DEFINE APPCOMMAND29 EFILIVESCAN
    5. Add it to your menu
    Attached Files Attached Files
  2. #792
    Jan 2010
    Ohio
    Another question, I have Iguidance 4.0, I got it to embed, sort-of, when I click the Iguidance button it loads the program but it loads it full screen, it is like 3 times bigger than RR, all the e-lite buttons work great, the size is just huge. Thanks again for all the help!!
  3. #793
    Aug 2005
    you are the man!
    thank you so much, it's working now.
    and btw loving your skin. having been playing with this stuff long but I really like what you have done.
    really looking forward to 2.x
    Heath
    First Carputer in progress.....
  4. #794
    Aug 2005
    one more question.
    is there a way to get the embedded app to close when the front end closes?
    right now I close rr with the exit button and my efi is still running in the background.
    not a huge deal but curious if is can exit with the front end?
    Heath
  5. #795
    Aug 2005
    slider, not positive if this will fix it for you but, I got it working ok making sure in my rr config I checked the external radio button and the ig native checkbox in the GPS section.
    Heath
  6. #796
    Jan 2010
    Ohio
    Yeah, i searched before and seen to try that, but I checked them both and it didn't work. Any other suggestions? Thanks again!
    *EDIT*Nevermind I figured it out, apparently I can't read!!
  7. #797
    Aug 2005
    how to for visualizations?
    is it skin specific or should I be looking for general RR instructions?
    Heath
  8. #798
    Aug 2005
    got em going.
    thanks!
    Heath
  9. #799
    Aug 2005
    ok yet another question.
    why does it on the player show the title of the song under artist and the Kbps and thats it?
    do I need to format my music a certain way? only works with certain version of winamp?
    other?
    thanks!
    Heath
  10. #800
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    one more question.
    RRConfig --> General --> Page 2 --> Close open embedded apps on exit.
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
