View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 82 of 101 FirstFirst ... 32727374757677787980818283848586878889909192 ... LastLast
Results 811 to 820 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #811
    Raw Wave
    Jun 2002
    Virginia
    Great work!
    Suavecito, I'm late to the eLite party but wanted to chime in and let you know what a great professional looking skin you have developed. I'm very much looking forward to the full version.
  2. #812
    Jan 2010
    I've run in a couple issues while manipulating the playlist/library in the audio browser..
    Using the latest 1.6 lite skin, and WMP to play mp3s.
    Start with a blank playlist.
    1) enter library
    2) enter random folder. double tap a song. song begins playing and the folder the song was in has all its songs added.
    2b) IF instead of double tapping the song, you instead hit "Add Folder" button, it will add the single highlighted track to the playlist. "Add" button does nothing.
    Blank playlist again.
    1) enter library
    2) instead of enter folder, highlight the folder and hit the "Add Folder" button.
    3) almost the same result. songs are listed, BUT now has the "." and ".." directory entries.
    This is OK except every time you restart RR, the files wmprr.m3u8 and rrpl.m3u8 get bigger and bigger. looking at it, each time RR starts, it parses the playlist, and goes throgh and RE-ADDS all files in "." and ".." - which is everything in my playlist. Restarting again repeats the process ad infinitum and crashes RR.
    Also - manipulating the playlist (open, save, rename) seems to be very awkward. I'm not sure why.
    Anyone else seeing inconsistent behaviour relating to the playlist/library browsing area?
  3. #813
    Jan 2010
    Ohio
    I agree, i'm having some issues with wmp and playlists too. All of my music shows up in the library, but it also shows everything in the playlist too. When I clear the playlist I can't seem to put just 1 song at a time on it, its all my music or nothing? I've searched and can't seem to find a faq or sticky about manipulating the playlists. I've made playlists in wmp, and set the directory of them in rrconfig, but they won't show in rr? Any help would be great!!
  4. #814
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by volvoman1 View Post
    Anyone getting this error?
    happens when i watch video, just pops up randomly. using windows media player as video player.
    Volvoman,
    I have been struggling with this issue also and think I have finally stumbled upon the solution.
    Go to the video section of RRConfig. I will bet that the Video Player Plugin is set to Media Player Classic. If you change that to Built-In I believe you will be good to go. This worked for me on both computers I was having trouble with. Please report back.
  5. #815
    Sep 2007
    Italy
    same error kbreeden, I also solved switching to built in player.
  6. #816
    Dec 2006
    I have 2 buttons call Amp On and Amp Off. I would like for those 2 buttons to just run 2 commands…that are
    C:\Volume_Amp_Control\Volume_Amp Control.exe (this turns the amps on)
    and
    C:\Volume_Amp_Control\Amps Off.bat (this turns the amps off)
    Is there away to do this or do I have to make a amp skin file or something. Here are 2 screen shoots
    http://i655.photobucket.com/albums/uu279/soloxp/RR0.png
    http://i655.photobucket.com/albums/uu279/soloxp/RR1.png
    Thanks soloxp
  7. #817
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by soloxp View Post
    and
    Thanks soloxp
    Change the buttons to the following codes instead of to a skin
    Code:
    SETTOPMOST;RR;TRUE||RUN;C:\Volume_Amp_Control\Volume_Amp Control.exe||ACTIVATE;Road Runner
    Code:
    SETTOPMOST;RR;TRUE||RUN;C:\Volume_Amp_Control\Amps Off.bat||ACTIVATE;Road Runner
  8. #818
    Newbie RockWilder's Avatar
    Nov 2009
    How do i go about putting a small display of visualisation from winamp on the audio player skin? that way eliminating the visuals button and having the visuals always on the audio player skin.
  9. #819
    Dec 2006
    [QUOTE=bratnetwork;1375777]Change the buttons to the following codes instead of to a skin
    Thank you sir...It works..
  10. #820
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by RockWilder View Post
    1. open the elite lite skin in the skin editor
    2. go to the audio_player.skin under the screen menu
    3. add an application, make the size and position to your liking
    3. click on the visual button and change to "VISU" (w/quotes)
    4. save
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
