View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 89 of 101 FirstFirst ... 39798081828384858687888990919293949596979899 ... LastLast
Results 881 to 890 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #881
    Newbie Scratch's Avatar
    Nov 2009
    North Carolina
    Quote Originally Posted by Enforcer View Post
    well your post is on page 44 for me, so I don't think that's going to work.
    Put the post number on in future.
    Good point...post #677
  2. #882
    Newbie pi3ch's Avatar
    Feb 2010
    Regarding to Album Cover, it still doesn't work even with elite 1.6.6 for 4:3 square screen. but here is the hot-fix:
    install elite 1.6.6 for 16:9 wide-screens then open General.ini file and modify show-height to 600 (so skin would fit you 800x600 square 4:3 screen). then you will find album covers working as well!
    remember to set rr config as well:
    http://www.mp3car.com/vbulletin/imag...be3d964732.png
  3. #883
    Sep 2005
    Configure new button to open Internet Explorer to web page
    Hello,
    Windows 7, Current version of RR , Elite Lite 1.6, Internet Explorer 8
    I would like to configure a button that when pressed opens the WEB Browser skin and then opens a specific webpage. I know I can setup Internet Explorer to open a home page and just use that , but I want to configure multiple buttons that open different web sites.
    How would I go about that?
  4. #884
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by skincommands.txt
    "WEBURL" - This allows you to make a shortcut button to specific URLs. The one parameter is the URL to open.
    Example: "WEBURL;http://www.yahoo.com"
  5. #885
    Sep 2005
    Thanks for the info. I am not a skinner and as such had not known of this command.
  6. #886
  7. #887
    Low Bitrate LordSnow's Avatar
    Jan 2005
    Louisville,KY
    I had been using this skin on another PC but recently upgraded to another PC and I'm trying to set up this skin on the new one. When I used this skin before, I could click and drag to scroll through the playlist and library, but it's not working on the new install. I have ensured that the settings match in RRConfig between the two PC's. Ilists are enabled. The latest DirectX runtime is installed. However, I was running a version of RR from late 2009 and I am now using the latest release.
    It's probably something simple that I am missing, but I haven't been able to find the answer on my own.
    Any ideas?
  8. #888
    Jan 2006
    Quote Originally Posted by Scratch View Post
    i applied the fix here and the OSK comes up great, however GMPC loses focus and goes behind elite.
    haven't seen anyone mention this, so i'm hoping there is a configuration error on my part. any ideas?
  9. #889
    Sep 2005
    Well the first place to start for any skinning commands is skincommands.txt in the documents folder.
    Well the WEBURL command works, however it only opens the page specified and does not open or load the wbrowser.skin file so that the on screen skin with buttons and so forth are present. I have tried a bunch of different combinations of the load;wbrowser.skin;weburl;www.yadayada.com and none that I have tried result in the skin AND the web page shortcut showing up together. I get either the skin or the web page. Doh!
  10. #890
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
