View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 95 of 101 FirstFirst ... 45858687888990919293949596979899100101 LastLast
Results 941 to 950 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #941
    May 2005
    Great looking skin. I like clean skins that don't look like they belong at a SEMA rice-car booth.
    I am new again to RR (used it years ago for a while) so please excuse this simple question.
    How do I change the arrangement of buttons? On the main page I don't need DVD/Video/HD Radio/etc...
    Sorry if this is a program question and not a skin question.
    Thanks.
    EDIT:
    Never mind, press and hold the button to select a new one. Perfect!
  2. #942
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by BrocasHelm View Post
    This skin is great, but I wonder if a red theme version of it is available(for text, progress bars as well as the icons like dimmer etc). I noticed that elite wings have different themes(blue, red, green etc), and I wonder if this does too. I couldn't find the option in the settings to change the theme. If there is such a version available to download, can anyone show me the link to it?
    Elite Wing uses variables to call each screen item / image and button and then renders the screen. As a result some user have noticed the a 2 - 4 second delay. Elite Lite uses one single image for the screen. Elite Lite 2 will have a similar function at a later time.
    Quote Originally Posted by cameronlazzari View Post
    I love this Skin. Very simple and easy to use. Quick question...how do I play CD's? When I select the DVD button it will eject my player but doesn't play my CD. Let me know...
    thanks,
    Cameron
    At this time Elite Lite does not support the CD function. This function has been added to Elite 2.
  3. #943
    Apr 2011
    I've just formatted my PC with Windows 7. I used to have centrafuse but after some nightmare with the audio outputs between the music, HD radio and Sirius which almost destroyed my 2000W sound system (Installed mitch HDradio program and somehow it made centrafuse folume go to MAX & gave me a little heart attack) I decided to move to RR and to use this skin.
    My question is, will this skin be compatible with the new RR update from June 2011? I'm crossing my fingers that RR will be a little more stable than CF but I dunno.... We'll see...
  4. #944
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    Post Fix for eLite not loading playlists in June RR
    I don't know if anyone else had this problem, but my M3U playlists wouldn't load in eLite after installing the latest RR (June 2011). I think it has something to do with:
    Code:
    from the RR June 2011 changelog:
    + Skin; 'AUDIO_PLAYLIST.skin" offically supported, will populate DL with
            ".m3u.m3u8" file types from your PLAYLIST PATH
            (no need for a "SD" definition)
    + Skincommand; "PLAYLIST" is alias to "load;audio_playlist.skin"
    Going to "Music --> Playlist --> Open List --> Load List" to load a playlist would simply return to the Music screen without actually loading the playlist.
    Here's the fix:
    In your eLite skin directory, make a copy of "load_playlist.skin" and rename it to "audio_playlist.skin".
    Then, open up "audio_currentplaylist.skin" in a text editor, find the line that says (it's line 47 for me):
    Code:
    "B,477,356,149,61,"Load;load_playlist.skin","
    and change it to
    Code:
    B,477,356,149,61,"Load;audio_playlist.skin",
    Voila!
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  5. #945
    Apr 2011
    Firstly, love the skin, makes RR a pleasure to use.
    Recently i put the time in to setup iGO8.3, and it works quite well. But i was wondering if it was possible to remove this bar in the guidance screen:
    The one highlighted in yellow.
    That way i could use iGO and be able to see the music playing and clock at the same time.
    Also is there any way to get the iGuidance link to start up in that mode, rather than starting with the bar down the left hand side?
  6. #946
    May 2006
    Calgary, Alberta
    I just did an update to the latest version of Road Runner and changed some settings, my videos are now playing very small and not full screen. They might be playing in their native resolution, not sure, it happens both inside and outside Road Runner. Is there a way to force it to full screen in Road Runner or this skin?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  7. #947
  8. #948
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Enforcer View Post
    Have you seen the thread on the latest MediaPlayer Classic Home cinema edition?
    Me? I don't know what that is, sorry. I've been away from the forums for about a year. Or more.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  9. #949
  10. #950
    May 2011
    Hi
    How can i get Enforcers RRFuelPrices 2.x to work in Ellite lite? He happy to add support for it if the author dont mind.
    How about it??
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 04:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 10:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 03:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 09:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 01:10 AM
