C'mon guys,...maybe cut suavecito a little slack here, he just needs to upgrade his wall clock that's all,...understandable right? :eyebrows:
Printable View
Okay, I downloaded RR, and downloaded this skin, The skin looks great! But I go to music, click add folder and nothing comes up to add the folder? Tried add playlist, same thing. I cant get any music onto it to play :(
Help?
You must go into RR Config and configure it to point to the music directory.
I have Elite with the latest version of RR and RRConfig. I also have the Directed HD Radio and Sirius Radio with MJS devices.
Problem is, Whenever I do a fresh open of RR and open HD radio or sirius, the station doesn't play and in the list, instead of my radio preset channels or my sirius channels, what I see is my playlist songs. I found a workaround it, I have to exit HD radio or Sirius, and click on music. Then I hit back, go back into HD Radio or Sirius and then the proper channels will show and the music will start.
Nitrodude, are you using WMP as your device for your music?
Suavecito,
Just doing my daily check of the thread. Still no update. Just wondering how long has the Alpha 2 release been postponed. You have a lot of us anxiously waiting, but no update since your pending update post. RR 8-1 has released and the weekend has passed. Just drop us a status if you can.
Bobby
I installed elite but get an error part way thru loading...
Here is what it says...I dunno what's wrong.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80010007): The callee (server [not server application]) is not available and disappeared; all connections are invalid. The call may have executed. (Exception from HRESULT: 0x80010007 (RPC_E_SERVER_DIED))
at System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
at Microsoft.VisualBasic.CompilerServices.VBBinder.In vokeMember(String name, BindingFlags invokeAttr, Type objType, IReflect objIReflect, Object target, Object[] args, String[] namedParameters)
at Microsoft.VisualBasic.CompilerServices.LateBinding .LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBind ing.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at RRVehicleMaintenance.RRSDK.GetInfo(String LBL, String FMT)
at RRVehicleMaintenance.RRExtension.WarningCheckTmr_T ick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr oc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
HDRadioRR
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/RideRunner/RadioModules/HDRadio/HDRadioRR.DLL
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
HDRadioComm
Assembly Version: 1.6.0.3
Win32 Version: 1.6.0.3
CodeBase: file:///C:/Program%20Files/RideRunner/RadioModules/HDRadio/HDRadioComm.DLL
VistaMixer
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/RideRunner/VistaMixerControl/VistaMixer.DLL
CoreAudioApi
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/RideRunner/VistaMixerControl/CoreAudioApi.DLL
Assembly Version: 2.0.2.0
Win32 Version: 2.0.2.0
CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/RRVehicleMaintenance/RRVehicleMaintenance.DLL
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Web
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RRWifiMan_NET
Assembly Version: 1.0.4061.14428
Win32 Version: 1.0.4061.14428
CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/RRWifiMan_Net/RRWifiMan_NET.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I was on vacation the past couple of weeks. I found some errors while testing the skin and didn't have time to fix them before going on vacation, this why the skin release was postponed. I will try to fix them as soon as possible and release.
Are you having this issue only with Elite Lite? Try using Carwings Lite to see if you get the same error. If you do, then it has to do something with Rider Runner. You may need to install it again.
I think you'll find this is to do with RRVehicleMaintenance, see red text in quote.
Check you have set it up correctly, or if you don't use it, remove it from the plugins folder.
If you do use it, post the error in this thread
Thanks guys...checking now
