View Poll Results: What Aspect Ratio / Screen Resolution do you use for eLite?
Voters
299. You may not vote on this poll
  • 16:9 (15:9) at 800 x 480
    119 39.80%
  • 4:3 at 800 x 600
    118 39.46%
  • 16:9 HIGHER THAN 800 x 480
    41 13.71%
  • 4:3 HIGHER THAN 800 x 600
    21 7.02%
Page 98 of 101 FirstFirst ... 48888990919293949596979899100101 LastLast
Results 971 to 980 of 1008
Thread: eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
  1. #971
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Quote Originally Posted by suavecito View Post
    Elite Lite will be released by this weekend.
    C'mon guys,...maybe cut suavecito a little slack here, he just needs to upgrade his wall clock that's all,...understandable right?
  2. #972
    Jun 2011
    Okay, I downloaded RR, and downloaded this skin, The skin looks great! But I go to music, click add folder and nothing comes up to add the folder? Tried add playlist, same thing. I cant get any music onto it to play
    Help?
  3. #973
    Jan 2011
    You must go into RR Config and configure it to point to the music directory.
  4. #974
    Apr 2011
    I have Elite with the latest version of RR and RRConfig. I also have the Directed HD Radio and Sirius Radio with MJS devices.
    Problem is, Whenever I do a fresh open of RR and open HD radio or sirius, the station doesn't play and in the list, instead of my radio preset channels or my sirius channels, what I see is my playlist songs. I found a workaround it, I have to exit HD radio or Sirius, and click on music. Then I hit back, go back into HD Radio or Sirius and then the proper channels will show and the music will start.
  5. #975
    Apr 2011
    Nitrodude, are you using WMP as your device for your music?
  6. #976
    Constant Bitrate besjr69's Avatar
    Feb 2011
    Suavecito,
    Just doing my daily check of the thread. Still no update. Just wondering how long has the Alpha 2 release been postponed. You have a lot of us anxiously waiting, but no update since your pending update post. RR 8-1 has released and the weekend has passed. Just drop us a status if you can.
    Bobby
  7. #977
    FLAC WuNgUn's Avatar
    Sep 2007
    I installed elite but get an error part way thru loading...
    Here is what it says...I dunno what's wrong.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Runtime.InteropServices.COMException (0x80010007): The callee (server [not server application]) is not available and disappeared; all connections are invalid. The call may have executed. (Exception from HRESULT: 0x80010007 (RPC_E_SERVER_DIED))
    at System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
    at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
    at Microsoft.VisualBasic.CompilerServices.VBBinder.In vokeMember(String name, BindingFlags invokeAttr, Type objType, IReflect objIReflect, Object target, Object[] args, String[] namedParameters)
    at Microsoft.VisualBasic.CompilerServices.LateBinding .LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
    at Microsoft.VisualBasic.CompilerServices.NewLateBind ing.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
    at RRVehicleMaintenance.RRSDK.GetInfo(String LBL, String FMT)
    at RRVehicleMaintenance.RRExtension.WarningCheckTmr_T ick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndPr oc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    HDRadioRR
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files/RideRunner/RadioModules/HDRadio/HDRadioRR.DLL
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    HDRadioComm
    Assembly Version: 1.6.0.3
    Win32 Version: 1.6.0.3
    CodeBase: file:///C:/Program%20Files/RideRunner/RadioModules/HDRadio/HDRadioComm.DLL
    VistaMixer
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/RideRunner/VistaMixerControl/VistaMixer.DLL
    CoreAudioApi
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/RideRunner/VistaMixerControl/CoreAudioApi.DLL
    Assembly Version: 2.0.2.0
    Win32 Version: 2.0.2.0
    CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/RRVehicleMaintenance/RRVehicleMaintenance.DLL
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Web
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    RRWifiMan_NET
    Assembly Version: 1.0.4061.14428
    Win32 Version: 1.0.4061.14428
    CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/RRWifiMan_Net/RRWifiMan_NET.DLL
    System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  8. #978
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by besjr69 View Post
    Suavecito,
    I was on vacation the past couple of weeks. I found some errors while testing the skin and didn't have time to fix them before going on vacation, this why the skin release was postponed. I will try to fix them as soon as possible and release.
    Quote Originally Posted by WuNgUn View Post
    mscorlib
    HDRadioRR
    System
    HDRadioComm
    VistaMixer
    CoreAudioApi
    System.Xml
    System.Web
    System.Drawing
    RRWifiMan_NET
    System.Management
    enabled.
    For example:
    <configuration>
    </configuration>
    Are you having this issue only with Elite Lite? Try using Carwings Lite to see if you get the same error. If you do, then it has to do something with Rider Runner. You may need to install it again.
  9. #979
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    mscorlib
    HDRadioRR
    System
    HDRadioComm
    VistaMixer
    CoreAudioApi
    System.Xml
    System.Web
    System.Drawing
    RRWifiMan_NET
    System.Management
    enabled.
    For example:
    <configuration>
    </configuration>
    I think you'll find this is to do with RRVehicleMaintenance, see red text in quote.
    Check you have set it up correctly, or if you don't use it, remove it from the plugins folder.
    If you do use it, post the error in this thread
  10. #980
    Sep 2007
    Thanks guys...checking now
  1. eLite Lite Mixer For Foobar2000 w/ 18-Band EQ
    By bratnetwork in forum RR Skins
    Last Post: 03-16-2010, 05:15 PM
  2. Help with riderunner and elite lite skin
    By Joshc8503 in forum Road Runner
    Last Post: 02-12-2010, 11:16 AM
  3. riderunner help - elite lite
    Last Post: 12-09-2009, 04:07 PM
  4. elite lite and lock button
    Last Post: 12-06-2009, 10:11 AM
  5. Preset problem in RR eLite Lite
    By aqua in forum Road Runner
    Last Post: 05-27-2009, 02:10 AM
