------------------------------------------------ FAQs------------------------------------------------
Most frequently asked questions:
1. How do I make eLite Lite fill my screen?
2. How do I add or replace a menu button on the Entertainment, Tools or Settings screen?
3. How do I clear a menu button from the Entertainment, Tools or Settings screen?
4. How do get Garmin Mobile Pc to work?
5. How do I get the Album Art to work?
6. Why do I get a greybox for the Album art?
The easiest way is select 800 x 600 (stretched) during the installation process. However, if you already have your settings set to your liking and do not wish to over write them you do the follow:
1. Download the appropriate file for your monitor:
For a 4:3 ratio screen (square) also known as a 800 x 600 resolution:
DOWNLOAD: General.ini (Right-click, then save as) For a 16:9 ratio screen (widescreen) also known as a 800 x 480 resolution:
DOWNLOAD: General.ini (Right-click, then save as)2.Goto the eLite Lite folder in your Ride Runners skin folder
3.Copy and paste the file you downloaded in
step 1, select yes to overwrite the current file.
1.Press and hold on the menu button you wish to add or replace on the Entertainment, Tools or Settings screen.
2.Once the selection menu is shown, select the button you wish add or replace with.
***Hint: the are 20 options per screen, press MORE, to view the last 20 options.
1.Press and hold on the menu button you wish to clear on the Entertainment, Tools or Settings screen.
2.Once the selection menu is shown, press CLEAR.
4. How do I get Garmin Mobile Pc to work?
1.Download and install the patch in post #1.
2.Press and hold on the menu button you wish to add or replace on the Entertainment, Tools or Settings screen.
3.Once the selection menu is shown, select GARMIN PC.
Click on the Image below for more information:
This skin uses flash for a visual effect on the album art. Please install the latest flash to resolve the problem.
------------------------------------------------ SKIN TIPS ------------------------------------------------
IMPORTANT INFORMATION:
To use the native IG navigation screen, make sure to select IGUIDANCE in the apps select menu.
To use the native Garmin Mobile Pc screen, make sure to select GARMIN PC in the apps select menu.
By pressing the eLite Lite logo on any screen, it will always take you to the Main Menu screen.
If you would like to use your own logo instead of the eLite Lite logo, go to the eLite Lite
folder in the skins directory and overwrite it with yours, but the file name must be elite.png.
By pressing the Time / Date on any screen, it will switch your skin form day to night or night to day.
By pressing the following icon on any screen, it will always take you back to the previous screen on any screen.
